Anyone think this is accurate?
   / Anyone think this is accurate? #11
I was looking for some ballast and found this on FB marketplace. I believe it’s about 30” wide x 24” tall x 24” deep. They’re claiming 1540 lbs. That seems exaggerated to me.
I made my concrete rear ballast with a metal frame that I set in wood forms and poured the concrete around it. It looks very similar to the one in your picture.
It's 24x24x33. The metal frame weighed 104 pounds. I used 25 sacks of 60-pound concrete for a total of 1,500 pounds. The total weight of mine is 1,604 pounds.
I put it on my 70hp Massey Ferguson 4707. The difference is night and day better when loading and carrying a fill bucket of dirt!!!!
Compared to mine, I believe the weight is accurate for the one you pictured.
  • Good Post
Reactions: jmc
   / Anyone think this is accurate? #12
Believe it or not, I made almost an exact copy of the one in the picture years ago. I had a lot of ready mix left over from when I had the base poured for my 2 GSI grain bins so I had the concrete truck pour the excess mix in a wooden box I made up real quick that sat on a 3 point material mover. Works well but I don't use it anymore and it just sits by the barn now. Don't require the rear ballast as both my M9's have cast rear centers. Maybe I should list it on FB marketplace and sell it.
   / Anyone think this is accurate? #13
Somewhere I have a picture of myself wearing a big straw hat using a cement mixer as well. :ROFLMAO:
   / Anyone think this is accurate? #14
Going back to my forklift manufacturing, virtually every “standard forklift” has a large cast counterweight on the back. It obviously works on forklifts everyday, it makes a lot of sense for some tractor applications.
We users have to guesstimate the amount of weight needed as a counterweight through trial and error. As an example, I often used my rotary mower or shredder as a makeshift counterweight. I removed it when I mounted other implements or the shredder made maneuvering difficult.
   / Anyone think this is accurate? #15
Isnt that similar (not same numbers by far) for using wheel weights/loaded tires? The cast counterweight is aways there to prevent tipping. A "farm tractor" doesn't really have an ideal location to mount a cast weight from to counter the loader and not interfere with the pto.
   / Anyone think this is accurate? #16
With the larger Kubota's at least, you can order cast centers when you order a tractor. Same applies to buckets. Kubota mounts a light duty material bucket standard, but you can order the optional heavy duty excavation bucket with a replaceable cutting edge or a welded on edge, your preference. I happen to own both styles and the 'Excavation' bucket is extremely more robust.
   / Anyone think this is accurate? #17
That was a good one. They last for a year, and then I have to buy a new one once it warms up again. Usually, they are under $10. If I'm outside, I have it on my head!!!
   / Anyone think this is accurate? #18
I own both types as well. The heavy duty bucket is indeed more robust. The only problem is, it weighs more, which lessens the lifting capacity of the FEL.
   / Anyone think this is accurate? #19
I've got 3-4 of them in varying condition... the oldest one gets worn in the pool! :ROFLMAO:
   / Anyone think this is accurate? #20
For the same money, you could get a 3pt to SSQA adapter. I use one with an old FEL bucket. I just back into a pile of gravel and scoop up a bucketful when I need ballast. Also comes in handy for using other FEL implements on the 3pt hitch.
View attachment 3347926 View attachment 3347934
Also makes a great carry all with the right bucket:
Plus left or right side tilt that you can't do with a loader mounted bucket.
Otherwise- are there lynch pin holes in the lower 3ph pins? Those would be a pain to drill at this point.
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2015 Chevrolet Cruze Sedan (A55853)
2015 Chevrolet...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
2012 FREIGHTLINER CASCADIA (A55745)
2012 FREIGHTLINER...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
