Brush hog safety chains
/ Brush hog safety chains #21
I'd go with belting. Just because of cost. Replacement bolts, nuts and washers will be the same either way. But you would probably have to buy chain. A probable source for belting is a gravel crushing plant/operation, concrete plant, etc. They go through belts fairly fast and will usually give you five or ten feet if you ask.
/ Brush hog safety chains #22
I am working on that exact same thing tomorrow. My 8 ft. Bush Hog finally lost the rubber belt in the front last fall. I used it without any safety issues, but in dry or dusty conditions, my tractor was covered with dust and chaff. Radiator screen would stop up every 3-4 hours and AC in cab would no longer work. This old bushog has seen a lot of heavy cutting and the rail where the belt attaches is all bent up. I will definitly put a belt back on it, but have to get the front, and the bar holding the belt straightened at a local welding shop.
I have not sourced a belt piece yet, and am afraid most sellers would not sell just a 8' long piece.
/ Brush hog safety chains #23
The rear is missing the most. If I can get a better idea over chains, I'd do both.
One of my thoughts was similar to yours, truck mudflap. Haven't thought about the design yet.
Fisher snow plow dealers sell a heavy rubber strip to put on the top of the plow. The one I put on mine is 7.5' x10" x 5/16". Fabric reinforced for moderate stiffness like a mudflap. Im sure it is available in different lengths.
/ Brush hog safety chains #24
You can also find it on eBay, and probably the jungle, (Amazon).
AS, I posted earlier, ask teh gravel and concrete plants. They have old belts lying aorund some of the time, they would be happy to sell or give you 8-foot of. It cuts ok with a jig saw, and some silicone lube.
/ Brush hog safety chains #25
Snow finally gone, at least where the grass is and I'm getting the brush hog ready for the field. The safety chains that prevent debris from coming out unchecked is missing quite a few links. I figured before I replace I'll ask my question...
Has anyone replaced the chain guard with anything else? If so, how'd it work out? Any pics?
I used truck mud flaps and bolted them on and cut slits in the male them flexible. The mud flaps cut easy with sheet metal snips
I had that though, but didn't think of cutting slits. I've used them on snowmobiles and they las longer than originals. Thanks.
/ Brush hog safety chains #27
What I'd be cutting is a hayfield and saplings. I've cut some of the unkept hayfield last year, tons of seed/chaffe plugging up radiator screen. Hoping to cut more often so it doesn't get to that point, dry and over grown. Time will tell how often, but the section I cut last year was about 6 times, vs my grass every week.
I've found Dec/Jan/Feb is a good time for that chore. I can see what was hidden by the leaves, and the chaff is gone by then. I have an open-station tractor, so I keep 2 insulated coveralls handy during cold weather.
I would have to do Oct-Nov-Dec due to snow. Thanks for the idea. And, dress for the occasion.
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
2019 International LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 International...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
