hayden
Elite Member
- Joined
- Sep 23, 2000
- Messages
- 2,543
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
OK, this is helping, and the key questions is whether the Fendt is just different, but perfectly usable for my needs, or is it really unable or super inconvenient to do what I want. Despite our instincts, we CAN learn new things.....
To Hay Dude, I'll have to double check but from what I currently understand the Fendt 200 & 300 work differently from what you describe for your Challengers in two significant ways.
First, I don't think there is a diverter valve to select between loader and rear use of SCVs 1 & 2 the way you describe. I'll re-check the operator manual, and can also take a dive into the parts book to see if I can find a diverter for that. But when I was discussing it with the Fendt factory rep, he talked about disconnecting the loader hoses to regain use of the rear remotes. And the manual is explicit that when you have a loader attached, you cannot have anything connected to the rear ports. And I haven't seen any button like you have to operate the diverter valves.
Second, I don't think it's possible to operate both the loader 3rd function and its alter-ego function at the same time. On the simpler loader joy stick, diverter control is an on/off push button, so the stick is controlling one function or the other depending on the button state, but there is no in-between setting where you can operate both at the same time. On the fancier joy stick there is a mini finger-operated joy stick on top of the primary stick, and that is used to activate the alternative functions. But I specifically asked the rep about that and what it does is first active the diverter just as though you pressed the button on the simper stick, then the thumb gives you proportional control without having to move the main stick. Now all this said, I make very little use of my loader 3rd function currently so this might not be a big deal for me, but I don't fancy the idea up an upgraded tractor that down grades parts of what I have now.
But I will double check both of these to be sure.
