(Mule) Deer fence construction recommendations
   / (Mule) Deer fence construction recommendations #21
The only 20’ high chain link fences I’ve ever seen were at correctional facilities. No animal can jump this, including the human kind.
   / (Mule) Deer fence construction recommendations #22
Those humans inside the correctional fences don't try acause of the corner towers have armed guards!
   / (Mule) Deer fence construction recommendations #23
Back in the 70's along NY17 SE of Liberty there would be a heard of deer on the hillside and highway, mabey 75-100 strong. They must have found a way around the fences that were put up to keep them away from the sweet grasses the highway department seeded along the shoulder.
   / (Mule) Deer fence construction recommendations #24
Hey Rocky, What can you do with deer netting arched over the rows of the newer plants? On a much smaller scale I used deer netting around the 1/2 acre property in Irondequoit, NY to deter the critters from the flowers and garden in a residential neighborhood. I say deter as when one morning I found one in the yard, it ran straight through the netting (used fish line to mend the hole) to escape my wrath as a discharge would have had the IPD at my doorstep. I had streched wire from telephone pole to trees to 2 inch pipe set vertically with bird house mounted on top(town board couldn't think of a way to make me take down the birdhouses) to hang the fence. It did look strange to see tiny lines of snow suspended in the air after a light snowfall.
   / (Mule) Deer fence construction recommendations #25
After doing a lot of reading we did a small test plot of 4’ fence. About 2’ inside we ran a string of blue pennant safety flags about 3’ high on t posts. Whitetail deer are sensitive to blue and the movement I think confuses them. Been a full year with consistent deer all around (camera) and no intrusions. They did eat everything outside tho…
Hopefully it works as we are expanding the area this year. 🤞
   / (Mule) Deer fence construction recommendations #26
It will work until the first kamikaze deer jumps it then you can't keep them out. At least that's how it is here.
   / (Mule) Deer fence construction recommendations #27
Mule deer step over a 4’ fence. Only a 8’ fence deters them.
   / (Mule) Deer fence construction recommendations #28
We've had luck with a 2 fence system. Inner fence was t-posts and cattle panels maybe 50 inches tall and outer fence is just a single hot wire using step in posts and a strand of poly tape (charged). Outer fence is placed about 3 feet from inner. Deer won't jump both fences at once and the space between the two is too narrow for them to easily land and jump again.
Also - a key thing is to not let deer get into the garden plot once. Once they've been in and gotten the taste, they will work a lot harder to get in again.
   / (Mule) Deer fence construction recommendations #29
Second idea I saw (never tried) in Farm Show magazine was regular T-posts set in place and 10 foot lengths of 1/2" rebar driven into the ground and attached to the T-posts. They attached either woven wire or cattle panels (2 rows high).
I'll come clean.
My first fence in 2017 was inspired by whatever I found on the internet. And what I found said "deer cannot jump up and out at the same time". So I put together something that was about 8' wide and 4' high.
In these 3 photos in series you can see the complete disregard this muley had for my "fence". From the crouch-and-spring in the 2nd photo to the sailing-over in the 3rd, this doe delivered humble pie.
Anytime I think I'm smart, I just look at photo 3.
SIMIRON SV3 HD VACUUM (A58374)
SIMIRON SV3 HD...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
APPROX. 100 GALLON TOTE W/ ANTIFREEZE (A52708)
APPROX. 100 GALLON...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2021 CATERPILLAR 299D3 XE SKID STEER (A52709)
2021 CATERPILLAR...
