Runner
Elite Member
- Joined
- May 12, 2007
- Messages
- 3,929
- Location
- Missouri
- Tractor
- 2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
There are a bunch of videos on YT showing how to do it. Here is the first one that comes up for me (shown on a lawn tractor, but the switch/plug is the same):Glad to hear you found a solution. Do you have a video or list of steps you can link to on how to disable it?
I put on the gator blades the other day but haven't had a chance to mow with them yet (probably tomorrow). Man, I had to use a 3' breaker bar to get the spindle nuts loose, and on 2 of the three needed a wrench on the head of the spindle nut to stop from just turning the spindle with it!
Think you'll ever consider adding the extra suspension to the seat?
So far, the reverse cutoff hasn't really bothered me much because you only have to push the button once when you start mowing. I'm mostly concerned that the button may malfunction, in which case I will perform the defeat mod.
I think the Gator Blades are a good alternative to the CC blades for normal mowing. They definitely seem more durable than the factory ones.
Since I aired the tires down, the ride isn't unbearable, and I really don't mind the bouncing as long as it doesn't shut off the mower every 2 minutes.... I will admit, I have given some thought to going back to mowing the big east yard (which is the roughest part) with the 2520/rear finish mower.
Still meditating on the suspension seat mod. It's looking better all the time
