Is there a safe way to pump gasoline into a plastic tank in the bed of a truck?
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck?
Here in New Zealand, all fuel outlets require the fuel nozzle to be earthed through the hose as a lot of new cars have plastic fuel tanks so along as you touch the nozzle to the tank you should not have any issues.
That would be great.
It's Tuesday and the night all the volunteer fire departments meet up. I'd going to head to the closest one and ask the same question regarding filling in the truck. Will post back what I hear.
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #62
I never let go of the pump handle when fueling. I keep my hand grounded to the pump at all times that way there won't be a spark between me and the handle.
Just got back from the fire station, very interesting. Insert every Alabama stereotype ever.
"Same as the dagum 5gal cans they fill in the back of pickup trucks all the time, shouldn't be any problem."
That was pretty much it. I'll call a different fire station tomorrow lol
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #64
Think; how do pickup owners fill the added 40G tank in the front of truck-bed?, How is the OEM plastic gas tank filled without danger?
You are grounded by standing on the ground/pavement, your hand on fuel nozzle.
OH, but don't talk on your cell Phone while pumping fuel. Glad that nonsense was debunked long ago.
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #65
I once worked for the biggest utility company in California. We had a gas truck and a guy who gassed all the big trucks every night and of course checked the oil. The truck had a custom made 50’ hose that was drug around as rolling it up took too long. It was cheaper to have a new hose made and use the good remaining end portions to make short hoses for the pump island. Most of the time when a new hose was made it was installed by the guy who filled the trucks. That was a classification of a lube oil change person. I was a journeyman hired there so wasn’t involved in that. One day I was going to get some parts and the lube man said hey can you stop by the hose shop and pick up the new hose for the gas truck? Just doing what I normally do I grabbed my meter to take with me??
When I got to the hose shop I looked the hose over and connected my meter (set to continuity of course) to the fittings on the new hose. But there wasn’t any continuity. I walked back into the hose shop and said this hose isn’t any good! What’s wrong with it?? Whoever made it up didn’t connect the anti static wire. The reply was what’s that!!! Moral of the story is you don’t know if the hose you are using is even grounded in the first place.
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #66
When filling a plastic gas container, always make contact with the nozzle to dissipate any static electricity, and prevent more from forming by the liquid flow.
If the plastic is not conductive, why does sitting it on the ground matter?
There would be no difference when filling the plastic gas tank for the vehicle.
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #67
Good question actually. I guess if the can combusts on the ground, less chance of your vehicle going up as well.
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #68
It can be conductive if the voltage is high enough. Static voltage can be very high.
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #69
That's right. A spark happens when electricity has enough voltage to jump across a low-conductive gap. Static electricity has very high voltage.
If If the plastic was conductive, current would just flow in the conductive material down to ground and no spark would happen.
Be safe,
rScotty
   / Is there a safe way to pump gasoline into a plastic tank in the bed of a truck? #70
I had never experienced static sparks from fueling, until last month. I had (2) 55 gallon drums of #2 heating oil setting on the bed mat in back of my truck, pumping them into an oil tank. Every time that I touched the steel pickup line I got zapped.
66'' root grapple (A53421)
66'' root grapple...
2018 FORREST RIVER CRUISE LITE CAMPER (A55745)
2018 FORREST RIVER...
2005 INTERNATIONAL 4300 SBA 4X2 BUCKET TRUCK (A52706)
2005 INTERNATIONAL...
2015 Ford Focus (A51694)
2015 Ford Focus...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
