20 inch chainsaw recommendation
/ 20 inch chainsaw recommendation #1
GlennMeyers
Kubota
Hi All,
I need to buy a new chain saw. I have a Husky 18 inch that is around 22 years old or so and the trees I need to cut up are too big for it. I figure a Husky or Stihl but open to other ideas as well. I would like to go with either brand's middle line, not home or professional but I think it is called Rancher series.
Secondly are there good online discount sites to buy or is buying local at a box store, hardware store TSC etc better?
Thanks so much,
Glenn
/ 20 inch chainsaw recommendation #2
Own a 20" bar Stihl 311 great power and saw when it starts. Next 20" saw will probably be an echo really like my 400 with 18" bar though very underpowered for larger rounds though but always starts easy in any condition or temp.
/ 20 inch chainsaw recommendation #3
Stihl 261C
Love mine
/ 20 inch chainsaw recommendation #4
Stihl 261C is amazing, runs a 20" no problem if your chain is sharp. Main reason I like the 261 over anything bigger is it is nice and light.
/ 20 inch chainsaw recommendation #5
A stihl 311 is definitely heavy however with a decently sharp chain I think actual use of the saw is reduced compared to less powerful ones. my lesser echo 400 is definitely light but cuts nowhere near as quickly as the 311.
/ 20 inch chainsaw recommendation #7
Get a pro saw. Buy once, cry once.
/ 20 inch chainsaw recommendation #8
Having both the Stihl 261c and Echo CS4910 - if they were cars, the Echo is a Honda and the Stihl is a Ferrari. If you want reliable running/easy start, get the Echo. If you want speed cuts and the Stihl name, get the Stihl, but it's finicky about it's start up routine. The Stihl was bought first (per the buy once cry once saying) and someone killed it and had to go into the shop. While there I picked up the Echo "for the meantime". Echo turned out to be a really good saw. Honestly, would have been nice to have bought it first.
Both saws will cut logs - keep them cleaned, lubed, fresh fuel, sharp chain. It's the cutting experience and cost of purchase that are different. I'm not blaming the break down on the Stihl, that was all operator error. But using them head to head for the same jobs, year round in all the 4 seasons, the Echo is much easier to live with.
/ 20 inch chainsaw recommendation #9
I too would only buy a Pro saw. It’s worth the extra $$.
Also consider Husky 562XP. I have the predecessor 262XP that is 30 years old and still screams through almost anything. Be sure whatever you get has a 3/8” chain, and not a .325”.
/ 20 inch chainsaw recommendation #10
What do you think is better about 3/8" chain?
/ 20 inch chainsaw recommendation #11
My 261C starts on the 3rd pull, every time. Reliability has not been an issue. Very easy to start & run.
/ 20 inch chainsaw recommendation #12
I've had Stihl and Huskies, I switched to Echo ~10 years ago and will never go back.
I'm currently running 3 Echos, small, medium and x-large. For felling and bucking the big stuff, the 680 pro saw is my go to.
/ 20 inch chainsaw recommendation #13
I think we can all agree the “big 3” and even some of the lesser marketed brands are all fine saws.
OP looking for suggestions on what saw and if he should buy on line, box, store, etc.
OP: I bought at my local Stihl dealer/ACE Hardware. It’s a big “country” type hardware store that sells a lot of farm supplies. To be a Stihl dealer, you usually have to repair them as well. You can buy Echo or Husky at Lowes, Home Depot, etc.
/ 20 inch chainsaw recommendation #14
I love my Echo 620p, Starts easy, cuts fast.
I have the 24" bar and it goes through Ash with nice big chips.
If you want to save money, the Echo 590 is a highly regarded saw, similar to the 620p.
I buy from a local place, not a big box store.
They are great at tuning it out of the box and for long term support.
/ 20 inch chainsaw recommendation #16
I’ll echo the Stihl MS261. It’s a pro saw but worth every penny.
I also like the pro saws. They're not that much more expensive than the farm/ranch saws and are a lot nicer to operate. Lighter, easier to start, more power, and built better.
However I think the 261 is a little small for a 20" bar, assuming that you're going to be using the full length. I'd go with the MS400.
/ 20 inch chainsaw recommendation #17
No problems with 20” here-just have to have a sharp chain. That is actually a good thing. Kinda forces you to keep on top of sharpening. Of course its a little slower in hardwoods.
/ 20 inch chainsaw recommendation #18
It just takes bigger bites of wood and will cut a lot faster provided the saw has the power. More chips, less dust.
/ 20 inch chainsaw recommendation #19
So it sounds like the 261 is better suited with the .325 if your running a 20" bar and cutting large rounds.
/ 20 inch chainsaw recommendation #20
Replacing 2 saws stolen out of my barn I went with a Makita 6421 for the bigger stolen saw. Back then they still sold them in that teal blue vs today orange. Makita bought Dolmar. I prefer that saw over my smaller Stihl but it's heavier so I tend to use the smaller 251.
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
New 31X13.5-15 NHS tire on John Deere 8-lug grain drill/air seeder rim, Coal Valley, IL (A65640)
New 31X13.5-15 NHS...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
