TC 33D Hyd leak from weep hole
/ TC 33D Hyd leak from weep hole #1
scalesusa
New Holland TC33D
My TC33d has hydraulic leaks at weep hole, it loses a lot of fluid. I saw a post where someone thought that o rings might be bad on tubes in the area, but no resolution. I wonder what could cause this. It does seem to be worse when using the loader.
Has anyone fixed this?
/ TC 33D Hyd leak from weep hole #2
Looks like you will need to split the tractor to find out. If not doing it your self..yes its expensive.
/ TC 33D Hyd leak from weep hole #3
Need to identify if it is engine oil or transmission oil. if engine oil , then it would be from rear main seal on the block. If that is the case then it might get on clutch and flywheel if you have manual transmission. This can cause slippage of clutch. If it is transmission oil, then transmission front case seal is leaking.
At any rate, this is not a good occurrence as repair needs to be done starting with a tractor split unfortunately.
/ TC 33D Hyd leak from weep hole #4
Unless he just changed his engine oil it wouldn't look like that. Even if he did it would most likely be darker than that already.
/ TC 33D Hyd leak from weep hole #5
I was making a general statement on the methodology to diagnosis. Can take the dipstick out to get a whiff of the oil on it. Doing the same with transmission oil to compare and contrast.
/ TC 33D Hyd leak from weep hole #7
Could be a tube o-ring, but when my 1520 had this leak, it was a shaft seal on the hydrostat unit. I split the tractor myself and took the hydrostat unit to a hydraulic shop to be repaired.
/ TC 33D Hyd leak from weep hole #8
I seem to have the same problem. But recently it morphed a bit. Instead of leaking from the weep hole, it started leaking higher up on the side of the casting where the tube from the oil cooler goes in. This tube is held in by a bracket that doubles as the mount for the springs for the clutch lever as well. Stupid design if you ask me. The other tube from the cooler goes in higher up on the casting and is attached with a proper banjo bolt and 2 o-rings. So when I removed this lower tube (it wasn't easy) i discovered that it goes through a cavity in the casting through to where it actually goes into the main casting inside. This cavity was filled with grit dirt oil and all kinds of goop and i'm sure that this is what is blocking the draining of fluid of this down to the weep hole. I've attached two pictures of the tube fitting and bracket that holds it in. It could very well be that this seal (o-ring) is compromised, or the bracket isn't holding it far enough in. Unfortunately, it looks like I will have to put everything back together and fill it all up with fluid (7 gallons) to find out. The o-ring is 4 bucks, I can shim the bracket if necessary... Guess i have to try. If the leak is coming from somewhere else in this cavity, it will then be apparent as it was really leaking fast at any decent rpms.
/ TC 33D Hyd leak from weep hole #9
Just adding some more notes here. As I was trying to clean out this cavity trying to prepare for the re assembly and test to see if it was the o-ring seal on the tube, I found in addition to the grime and built up oil, actual pieces of nuts (tree nuts) and evidence that there was probably mouse activity or some such in this cavity. I mean good size pieces of nuts (like 1/2 to 3/4 inch kinda chewed up) What??? How and where is there a hole big enough in this cavity for rodents to get stuff in/out? Is there a cover missing somewhere? Where would that be. I have not yet taken off the entire assembly below the seat (the big body piece) as it would entail taking off the controls etc to lift it all off. I"m also concerned that I can't really get to the very bottom of the cavity where the weep hole is to thoroughly clean it out through my access point (which is where the cooler tube goes in. Yeah, yeah I know, split the tractor get to the bottom of it. But if it is only the o-ring seal on the tube, then theoretically everything else is un necessary
/ TC 33D Hyd leak from weep hole #10
On my tc29d, it was exactly the same as yours. I replaced orings because thats the area it was leaking. I cleaned out the weep home, tons of grass and sludge. Still leaks to this day. Leaks more at high rpm when using belly mower. Unable to split the tractor myself, no one else wants to touch it. Even dealer said leave it, will get to it when we can, at least 6 months...
Between that, needing 4 tires, and other items, I bought a new tractor. hydro oil is cheap enough for me to use as is, so I can use belly mower. 5 gallons in over 400 hours.
Good luck with yours.
/ TC 33D Hyd leak from weep hole #11
Thanks for your post!! I am not alone lol. Do you think replacing the o-ring slowed it down any? I actually measured the o-ring I removed and it seemed close to what the nominal called for in that part. I am going to try a new one of that size or maybe one slightly bigger, as long as I can shove the pipe in. Still a little worried that it isn't this o-ring at all, and it's somewhere else in this cavity. recently it seemed to be leaking a lot more )I was using a PTO chipper and running the tractor at high enough rpm to get the PTO to 540. I will be putting it back together shortly with a new o-ring to find out. By the way, I bought a tractor freight fluid extractor (air powered) to suck the sludge out of the cavity so that it can drain from the weep hole again. Perhaps if I have to live with it a while such as you, I can rig up a little catch pan under the weep hole like a diaper for my hydraulic fluid lol
/ TC 33D Hyd leak from weep hole #12
Digging deeper on this. I've attached a snapshot of one of the pages of the service manual for the TC33D. It shows the HST pump and it's relation to the housings and piping and filters. Seeing this, it now makes a little more sense. The HST pump and motor is "inside" the cases and the lines and fittings that I have been showing go through the sides of the case to the pump inside. I think the HST pump actually "lives" halfway in one case and halfway in another. The charge pump side of the HST pump lives in the dry side where the clutch and shaft from engine are. And the HST motor side of the pump lives in the rear transmission case. The HST pump is attached to this case by four bolts. You can see in the picture where the tube from the oil cooler with the suspect o-ring goes into the HST pump. Of course there look like there are other places on that side of the pump where it could be leaking into that cavity. Again of course with no way of knowing without splitting the tractor apart. I guess there is an outside chance that it isn't hydraulic oil at all, but engine oil from the rear main seal leaking into the dry area where the clutch and output shaft are? I don't think this is the case, as I never noticed the engine oil level dropping when the tractor was spewing the fluid. Really hoping that it is the o-ring on the cooler tube, but don't have a good feeling about it. Stay tuned for results of test.
/ TC 33D Hyd leak from weep hole #14
Yeah. I don't know if it's the exact same area leaking, but after seeing this I am sure it's not the o-ring. Your thread was super illuminating. I have the TC33D service manual and can see all the diagrams and drawings of everything, but there is nothing like seeing it in real pictures. I was wondering what the HST pump/motor assembly actually looked like. I am a mechanical engineer, and am confident that I could probably do the split. But I don't currently have the garage/shop space for it. What would be really nice on this tractor is if there was an inspection plate on the bottom of the casting where the weep hole is. At least you could remove that and see where the heck the fluid maybe dripping from. I mean that is a "dry" area, so what the heck, put a plate down there...
/ TC 33D Hyd leak from weep hole #15
The plot thickens. Finally was able to reach the dealer (I had been to this one before). Talked to their service manager. He was pretty familiar with the problem. Believes it is the seal on the input shaft to the HST pump. Without prompting he told me that what happens on these machines is that the "dry space" where the pump is gets sometimes filled with grit grime etc. because there is a golf ball size "inspection" hole at the top of that casting. Worse yet, he said that rodents sometimes get in this space and fill it with more debris. This gets onto the input shaft and works its way into the seal, and destroys it.
It was then that I told him that I had been pulling sludge and acorns out of an access point that was created by my removing one of the hard lines that goes into this housing. What a stupid design (new Holland) that allows this to happen. Sure have a vent/inspection hole on top of the casting, but have a damn screen over it to prevent this!!
Anyways, If it is just the seal, the approximate cost for the whole job is 2 to 2.5 k. Mostly all labor to get to everything (splitting the tractor and putting it back together.. I was expecting this (actually was expecting a good bit more). They could schedule the job at end of June. I was going to do it myself, Now I am back on the fence...
/ TC 33D Hyd leak from weep hole #16
That doesn't sound good.
Are you able to see the "inspection hole" that the mice were able to get through? Any pictures?
/ TC 33D Hyd leak from weep hole #17
No you can't see it because it is below all the plastics "body". It would be pretty much directly below the steering wheel area. Gone are the days when the "body panels" of tractors were pretty non existent. Will only really see this area when the tractor is split and you can clearly see the top of that transmission housing. The engineers should have put an inspection/cleanout plate on the bottom of the housing where you could just remove it and clean the space out thoroughly. I'll certainly get pictures if I do the work myself, or maybe get some when it's at the dealer. skramer360 has some great pictures in his thread on this topic, where he split the tractor and you can see all the housings and cases
/ TC 33D Hyd leak from weep hole #19
That is the same outcome as I fear mine is. Exact same conditions... no nuts in mine, but grass sludge.
At this time, I don't want to spend that much money on it, if I could even find someone. Hydo oil is cheap, and with new tractor, will get much less use.
Good luck.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
FUEL PUMP W/NOZZLE (A60736)
FUEL PUMP W/NOZZLE...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
DEUTZ MARATHON...
