Tires for Kubota RCR48 mower deck?
/ Tires for Kubota RCR48 mower deck? #1
998cc
Member
Northern California
B7100HST
Hello again to the group.
What are folks using to successfully replace the original tires on these mower decks? I have tried replacing one with new chinese tire and tube, and it failed after a few hours use. Photo attached of an (I believe) original tire. Size is 2.80/2.50-4. Outer diameter is roughly 8 inches.
Thanks.
Russ
/ Tires for Kubota RCR48 mower deck? #2
Those look like basically hand truck or wheel borrow tires... Would think some "flat free" tires/wheel may be appropriate...
More specifically....
/ Tires for Kubota RCR48 mower deck? #3
I could never go back after running solid wheels on my (different) mower. I think mine are 6" OAD , and most sizes should be available online or through the OEM.
I'm curious what you end up with.
/ Tires for Kubota RCR48 mower deck? #5
You might be right. Come to think of it, I’ve seen them both ways.
edit: Just saw OP posted new picture showing cap and relay behind cover. Sorry about the confusion.
Fill your failed tire with expanding foam and call it good.
What type and brand of foam.... Surely not wall insulation foam....
/ Tires for Kubota RCR48 mower deck? #6
I've used insulating foam (limited expansion) in the past on small, easily deflated tires. I removed the valve core and stuck the straw directly into the stem with the stem at 12 o'clock and allowed the stuff to cure with no issues.
Works well especially on wheel barrow tires that like to go flat on their own.
/ Tires for Kubota RCR48 mower deck? #7
Look for tires and tubes made in USA, Vietnam, Thailand or Korea. The Chinese just haven't figured out quality rubber compounds yet. I've never had any rubber products from China last over a year.
That size tire is as common as fence posts. You're just not looking. :p
/ Tires for Kubota RCR48 mower deck? #9
People on RV forums refer to them as 'China Bombs'
When I was counting pennies years back, I skimped and saved enough to buy four new Zhōngguó-tires for my 81 Chevy truck. Within a year, I had two of the tires blow out just sitting in the driveway. The blow outs were within a few months. Blew the tread right off of them. That's when I said, "No More".
I can't count the number of times I've replaced other small tires and air hoses over the years. They just rot without being used. :rolleyes:
/ Tires for Kubota RCR48 mower deck? #10
Sounds like the Chinese tarp straps at HF. Guaranteed to rot away in a year. Besides, they stink.
/ Tires for Kubota RCR48 mower deck? #11
I ended up switching to a solid rubber tire from a local hardware store, and it’s been holding up great. You lose the air cushioning, but no more flats.
Tinhack,
Thanks for the response.
I have looked, and the only tires I am finding are tail wheel tires for small aircraft. No way to tell where they are made, but they are about $80.00 each. At $80.00 each, I would like some assurance they are robust and can be used reliably in this application. Whatever the case, components certified for aircraft use always come development and liability costs included in the price tag.
The original Kubota tires were made in Taiwan and lasted decades.
Is there another source?
Russ
Good thoughts. Did you find tires only or did they come formed on the non-split rims? I bought some like this on Amazon but upon inspection, doubt the rims will take the punishment. Will try them.
/ Tires for Kubota RCR48 mower deck? #14
Taiwan used to be a good place for rubber, but I haven't seen tires made there in quite a few years.
Are you looking for a tire and tube or the whole wheel assembly? There's a huge difference in what you'll find for assemblies.
I'll take either one. Pneumatic tires as originally fitted would be fine. However, a solid-rubber tire that would fit the Kubota split rim might be fine. The bearings in the stock Kubota wheel are wide roller bearings and spread the load very well. New wheels seem to come fitted with cheap ball bearings.
10222 (A56858)
10222 (A56858)
2006 International 4300 Altec LRV58 58ft Forestry Chipper Bucket Truck (A61568)
2006 International...
Topsoil Trommel (A57453)
Topsoil Trommel...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2021 CATERPILLAR 262D3 SKID STEER (A62129)
2021 CATERPILLAR...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
