No power to starter x485
/ No power to starter x485 #1
Refdad
2004 JD X485
JD X485. Power to fuel pump and instrument cluster. No power to starter.
/ No power to starter x485 #2
I don’t think the safety switches cut power to fuel pump or instrument cluster but they do affect the start circuit and ignition circuits. I would start by verifying operation of seat switch, neutral switch and PTO switch. I believe they all tie into the start and or ignition circuits.
If memory is correct Deere also had some circuit boards in the start circuit on that model.
I’ve checked seat switch, but have only found 1 switch that controls rto. I replaced the pro switch. I checked and cleaned relays. I guess it’s in the circuit board. Looks difficult to test. Thanks for your help
Also, can’t find a switch for brake.
/ No power to starter x485 #5
Welcome to TBN
What is rto? What is pro switch ? Maybe typo's, but maybe something else.
/ No power to starter x485 #6
Post removed.
Sorry, for typos, RTO switch is reverse pto, also , checked the neutral switch under pedals. I accustomed to seeing a brake switch, but can’t seem to find it.
/ No power to starter x485 #8
I believe TM2023 is the Deere technical service manual for the X485. Deere typically have very detailed wiring diagram and diagnostic instructions. My suggestion is to invest in the manual.
Thanks, I will
/ No power to starter x485 #11
You can order and download TM's (they are pricey) from JD's tech pub site: Search for Equipment Publications - Technical Information Store
What isn't pricey today? I thank the Lord I have access to all the Kubota shop manuals at the Kubota dealership I work at part time. Sticker shock is a Kubota shop manual and I bet JD is up there as well.
If there is no power to the starter, first thing I'd look at is the starter solenoid They can mysteriously fail.
/ No power to starter x485 #12
On one of my 322's I had to replace the wire from the ignition to the starter solenoid as it had built up corrosion that didn't allow current to flow.
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
Forklift (A56857)
Forklift (A56857)
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
John Deere TX Gator (A60462)
John Deere TX...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
