What to look for in a Skid Steer.
   / What to look for in a Skid Steer. #12
Chainsaw and a grapple to get the trees down and burned. A forestry mulcher to "civilize" the woods.
Connected to a Compact Track Loader?
   / What to look for in a Skid Steer. #13
If 5 acres have you considered renting a machine with mulching head.
Or contracting it out. 5 acres would be a 1 to 2 day job depending on the site and type/number of trees for someone with a mulchine head.
   / What to look for in a Skid Steer. #14
I would do some pricing a 100 HP CTL if bought new is going to run you around $100k, a brand name mulching head a minimum of $25k, add stump buckets, forestry brushcutters, grapples etc, you see where I'm going. I have a 75 HP CTL and do a lot of work with it for other people as a retirement side gig but I don't jump on jobs to remove lots of 20" trees, I consider myself proficient at lot clearing, property clean-up, underbrushing, forestry mowing, tree and debris removal with a grapple and chainsaw but a 5 acre land clearing job with 20" trees is better left to someone with a track hoe, wheel loader and dozer IMHO. Good luck with whatever you decide but look at what all your options are before you spend a dime. Charlie.
Tracks, grapple, stump grinder, and possibly a stump bucket. Got it.
@jk96 said "For clearing, the larger you can afford the better.". What would be the minimum I should consider?
What would be the minimum hours I should consider if I do not buy new? (never owned a skid steer before).
would a Kubota SVL75-2 work?
More info. Going to clear about 5 acres of land trying to keep the big hardwoods. Also demo of 2 trailers on the property.
Will be creating a pasture for mini cows and mini horses/shetlands. Also creating a small area for breeding.
Will be using the Skidsteer and my L3540 for general maintenance afterwards.
   / What to look for in a Skid Steer. #16
My only comment on skid steers is not a Kubota, even though I own Kubota tractors and hay tools, I've read Kubota skids have issues and they are difficult to service as well.
thanks for all the replies. Was looking at a SVL75-2 since the long term will be maintenance. I've seen that model take trailers down, so I can actually do that. Contractors want $10k per trailer for removal so will pay for some of the skid steer. Plus, it would be a great toy to play with and learn on. (kinda a Kubota fan boy, but not locked in if it makes financial sense)
What is the maximum hours I should consider.
Will probably consider contracting a dozer for the major work and cleanup with a skid steer, just worried about a dozer being able to be nimble enough for working between the larger trees I want to keep. Also worried about hurting the root system of the bigger trees so maybe a skid steer with a stump grinder is a good option.
Once again, thanks for the replies.
Good info to know. What would you/all recommend?
   / What to look for in a Skid Steer. #19
Skid steers have a lot of parts crammed in a small package. Which ones aren’t hard to work on? I’d like to know so I can go buy one.
   / What to look for in a Skid Steer. #20
It helps if you can dislocate your shoulder like Houdini,
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
Towable Dewatering Pump (A59228)
Towable Dewatering...
2003 Big Tex 10PI...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
1979 Ford H-48 Excavator (A56438)
1979 Ford H-48...
