What to look for in a Skid Steer.
   / What to look for in a Skid Steer. #12
Chainsaw and a grapple to get the trees down and burned. A forestry mulcher to "civilize" the woods.
Connected to a Compact Track Loader?
   / What to look for in a Skid Steer. #13
If 5 acres have you considered renting a machine with mulching head.
Or contracting it out. 5 acres would be a 1 to 2 day job depending on the site and type/number of trees for someone with a mulchine head.
   / What to look for in a Skid Steer. #14
I would do some pricing a 100 HP CTL if bought new is going to run you around $100k, a brand name mulching head a minimum of $25k, add stump buckets, forestry brushcutters, grapples etc, you see where I'm going. I have a 75 HP CTL and do a lot of work with it for other people as a retirement side gig but I don't jump on jobs to remove lots of 20" trees, I consider myself proficient at lot clearing, property clean-up, underbrushing, forestry mowing, tree and debris removal with a grapple and chainsaw but a 5 acre land clearing job with 20" trees is better left to someone with a track hoe, wheel loader and dozer IMHO. Good luck with whatever you decide but look at what all your options are before you spend a dime. Charlie.
Tracks, grapple, stump grinder, and possibly a stump bucket. Got it.
@jk96 said "For clearing, the larger you can afford the better.". What would be the minimum I should consider?
What would be the minimum hours I should consider if I do not buy new? (never owned a skid steer before).
would a Kubota SVL75-2 work?
More info. Going to clear about 5 acres of land trying to keep the big hardwoods. Also demo of 2 trailers on the property.
Will be creating a pasture for mini cows and mini horses/shetlands. Also creating a small area for breeding.
Will be using the Skidsteer and my L3540 for general maintenance afterwards.
   / What to look for in a Skid Steer. #16
My only comment on skid steers is not a Kubota, even though I own Kubota tractors and hay tools, I've read Kubota skids have issues and they are difficult to service as well.
thanks for all the replies. Was looking at a SVL75-2 since the long term will be maintenance. I've seen that model take trailers down, so I can actually do that. Contractors want $10k per trailer for removal so will pay for some of the skid steer. Plus, it would be a great toy to play with and learn on. (kinda a Kubota fan boy, but not locked in if it makes financial sense)
What is the maximum hours I should consider.
Will probably consider contracting a dozer for the major work and cleanup with a skid steer, just worried about a dozer being able to be nimble enough for working between the larger trees I want to keep. Also worried about hurting the root system of the bigger trees so maybe a skid steer with a stump grinder is a good option.
Once again, thanks for the replies.
Good info to know. What would you/all recommend?
   / What to look for in a Skid Steer. #19
Skid steers have a lot of parts crammed in a small package. Which ones aren’t hard to work on? I’d like to know so I can go buy one.
   / What to look for in a Skid Steer. #20
It helps if you can dislocate your shoulder like Houdini,
Kubota B21 TLB (A60462)
Kubota B21 TLB...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
