Lombardini small 4wd tractor spinning wheel
   / Lombardini small 4wd tractor spinning wheel #1
alaaahmad
Lombardini
We habe old lombardini 4wd if we attach the blough to the tractor the front wheeels start spinning in its place and not move and some time one spin and the other not move even we put small resistans in back it will happan can you advice
   / Lombardini small 4wd tractor spinning wheel #2
Lombardini makes engines, not tractors. What tractor do you have that is powered by a Lombardini engine? Pasquali? Goldoni? Agria? Ferrari? Valpadana?
Also, what is a "blough"?
Thx for reply its very old can i share avideo for it and the problem i dont know exactly the manufactrur but sure it hav lombardine engine
   / Lombardini small 4wd tractor spinning wheel #4
Oh cool. That's possibly an Agria 9900EL or Z.
So what is exactly the issue? Rear wheels spinning? There is a lever that engaged the 4WD. It's on the right side of the main gear lever (1st through 4th gears).
I dont know the plough in english but its look lik called harrows the tool connected to the tractor to go in the land
Can i share avideo here so you can see the issue, unfortunilty ,it telling 10sec video about 4 mgbite is big whin i attach, bytheway the font wheel not the reare is spinning and we use thelever lever but i dont think the issue it from it
   / Lombardini small 4wd tractor spinning wheel #7
Easiest way is to upload the video to Youtube, then share the link here.
This is ferst time in my life i add video to youtube so can you check if it visible to you
   / Lombardini small 4wd tractor spinning wheel #10
Video worked well. I suspect you have broken teeth on the pinion, ring gear or both. Or best case scenario, it sheared the bolts that hold the ring gear to the differential carrier. Another possibility is a broken final drive gear or stripped splines.
If you remove the top cover of the rear gearbox, you should be able to see what the problem is.
Here is a picture of my Agria 8900D. Should be very similar to yours. This was before I took it all apart so it's still very dirty.
MASSAGE CHAIR (A58214)
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
