etpm
- Joined
- Jun 30, 2021
- Messages
- 2,338
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
You could also just use a file to file through the wall of the pipe until threads start to show. There is a tool made for removing pipe nipples that most good hardware stores sell. This tool has splines and a splined wheel that has a hole drilled off center. When inserted into a pipe and turned the wheel cams outward and grabs the inside of the pipe. Cutting a groove in the pipe wall and then using some penetrating oil along with the tool could just do the trick. Just let the penetrating oil soak in for a while.Thanks for the replies, I tried the ez out this morning and got a good bite on it but it still didn't want to break free. I put some pretty good pressure on it but think i might break the ez out if i try any harder. Ill let it soak in pb blaster for a few more days and try again, if that doesn't work then i will break out the dremel and see what i can do.
Eric
