Ford 1953 Spin On Oil Filter Foiled By Stuck Bushing On Block
   / Ford 1953 Spin On Oil Filter Foiled By Stuck Bushing On Block #1
LTA13
Idaho
1953 Ford
I have a 1953 Ford Jubilee with a leaky original oil filter cartridge assembly that I am trying to convert to a spin on filter. Bought one of those aftermarket conversion kits from Yesterday's Tractor. The kit has an adapter that screws into a threaded hole on the block after the factory bushing is removed.
My problem is that I cannot remove the factory bushing that is male outside threaded (mates to the block) and female inside thread (accepts stem/bolt that goes through the original cartridge). I have tried WD-40, a little heat (wimpy BBQ lighter), and as much torque on the threads of the bushing that I dare to use without stripping the threads or crushing the hollow bushing.
Any one out there faced a similar problem and found a solution to removing the stuck bushing?
Thanks.
   / Ford 1953 Spin On Oil Filter Foiled By Stuck Bushing On Block #2
Had the same problem on my 641. ended up using a deep well socket and a LONG handled ratchet to reove it. Why are you worried about crushing the hollow bushing.
? If you crush it,then it should fall out, problem solved! Install new bushing supplied and install filter!
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
FUTURE 6' CLIP-ON FORK EXTENSIONS (A60432)
FUTURE 6' CLIP-ON...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
