Ford 1720 coolant piece broke in block
   / Ford 1720 coolant piece broke in block #1
swarley814
Ford 1720
Anyone have any ideas on how to fix this? I have a 1990 ford 1720 that had a coolant hose leak down by the drain, tried to take the hose off the replace it and the nipple it attaches to broke. I tried removing the whole piece that threads into the block and that also snapped off. I had a breaker bar on it when it snapped so I got some good torque on it and the threads didn’t break loose. That makes me think using an easy out probably won’t work. Any other ideas or am I SOL?View attachment IMG_7838.jpeg
   / Ford 1720 coolant piece broke in block #2
I would clean up the area and dry it off. Then i would try squirting penetrating oil on the threads (WD40 is not penetrating oil) and keep it wet for a week or so. Then I would try an ez out and see if I could get it out. Don't snap off the ez out!!!
If that fails, I would use a die grinder or dremel and see about grinding the metal down, until I could just see the threads in two areas on opposite sides. DO NOT damage the threads. Put a rag in first to keep metal out of the engine. Then I would take the ez out and put it in, making sure the teeth of the EZ out were not on my ground down areas. In theory the ground down areas will flex allowing the ez out to unthread the broke piece.
If that fails I would grind two more areas down. Making sure to put a rag in first to keep the metal out of the engine. Then i would use a cold chisel and try to spin the broken piece out.
If that fails I would then use the cold chisel to beat the pieces in collapsing the broken part. Once you get one piece broke out, the rest will most likely fall out with a tap.
There are other ways to handle this, however this would be my approach. Take your time and don't damage the threads. Also don't use a breaker bar on the ez out, your changes of breaking it off are too high.
Thank you, just ordered an ez out set that has one large enough for that size. Hoping I can break it free.
Also, is this piece only meant for draining coolant out of the block? The tractor is getting pretty rough anyway so worst case scenario would i be able to just plug that hole if i can't get the old plug out? Obviously i would no longer be able to drain the coolant out of the block but would that be the only difference?
   / Ford 1720 coolant piece broke in block #5
Alternately you could drill the hole out to the right size for a pipe tap and thread the hole. Either plug it with a brass pipe plug or pipe threaded valve. If only using it for draining the block a brass plug would be good enough.
   / Ford 1720 coolant piece broke in block #6
I wouldn't recommend a tapered extractor, they have a tendency to damage castings from the pressure they exert.
Look for a splined style for pipe, they are specific to size.
If that doesn't work, the die grinder mentioned earlier, very carfully with a carbide burr or even a stone, cut into the fitting as deep as possible without getting into the threads in 2-3 places, then collapse the peices.
It's a not easy and has the risk of damaging the bung, but sometimes it's the only choice.
Thanks for the replies, I tried the ez out this morning and got a good bite on it but it still didn't want to break free. I put some pretty good pressure on it but think i might break the ez out if i try any harder. Ill let it soak in pb blaster for a few more days and try again, if that doesn't work then i will break out the dremel and see what i can do.
   / Ford 1720 coolant piece broke in block #9
Drill it and tap for a pipe thread.
   / Ford 1720 coolant piece broke in block #10
Perhaps if you drill it out and leave enough medal so a easy out
could get a grip after soaking with penatrating oil??
willy
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
