part-time-Farmer-NC
- Joined
- Oct 7, 2024
- Messages
- 929
- Tractor
- Kioti DK45Se
Just curious, would a shot of ether help? Maybe getting it to run would suck out the air in the fuel lines?
Manual lever would be on the lift pump attached to the engine, not the filter.No manual pump on filter, thanks for the thought
Fuel bowl is full
Got the tractor on a jump so I know there is enough voltage.
Is the hose collapsing when you crank the starter? Sounds like you might need a new fuel line.So I took off the hose on the back of the filter, the one that seems to take fuel from the filter not send fuel to the filter. I was stopped up once again. So I sucked and blew (NO COMMENTS) in it until I got air going thru again.
The engine sputtered for a few seconds. Tried some more letting the starter cool. Back to the same cranking forever.
I then "recleared" the same hose. Once again it was blocked up. Tractor began sputter again for a few seconds then back to cranking.
It goes to something on the engine then goes to the fuel vent thingy I opened to start it.
What keeps blocking it up. It seems to go past the filter so I would not think it would be trash.
It might be, I haven't even looked. Which line would you be referring to? Two lines supply fuel to the filter, and then one goes to the fuel pump.Is the hose collapsing when you crank the starter? Sounds like you might need a new fuel line.
Start with replacing the fuel line/hose that has repeatedly gotten blocked.It might be, I haven't even looked. Which line would you be referring to? Two lines supply fuel to the filter, and then one goes to the fuel pump.
