6 volt coil question
/ 6 volt coil question #21
12V test light will work, will just be dimmer. I use mine on all of my tractors 6V & 12V both.
/ 6 volt coil question #22
I use automotive coils interchangeably. A good one is good for decades. All that matters seems to be the voltage. Polarity doesn't matter to any coil I've used. My JD is 12 volt positive ground, so any 12 volt coil works. To test it I just lay a spark plug on the engine block, hook up the wires, and interrupt the low voltage points wire.
I have found that the spark plug cable is often a culprit in weak spark. Now I use copper stranded core spark plug cable -Belden brand wire with neopreme plug & coil ends that I got at a vintage auto show.
This sure has been an old fashioned winter, here in the north west corner, of NY state. Not sure what happened to global warming ? For the first time, since my Farmall Cub quit running in January, it’s warm enough on a weekend to work on my broken down “off-brand”tractors out in my unheated barn.
Even though I will
likely “need” my Ford 8n before the Farmall, I’m going to start with the Farmall because it’s likely to be the quicker fix. The “brilliant” engineers at Ford, designed it so that the hood and gas tank need to be removed to work on the coil.
I really don’t need either one of them since my grandpa was wise enough to replace his team of horses with John Deere tractors, as the primary power on our farm, back in 1950. I’ve always had a green tractor available to get the work done when it really needs doing.
If I can’t get the Farmall going today, I’m going to winch it onto a trailer and drop it off at our local, semi-retired Farmall mechanic’s shop. He got it running real good for me a few years ago, after it had sat unused in a factory building, for about 20 years. He loves working on Cubs. I’m still working full time and then some at my factory job, so I may not have the free time that it takes to get this one, and my old Ford, running good again.
Sounds like more of an electrical connection problem being that it died that quick. A simple test light will help you diagnose that problem. Put the clip end on a good ground, battery is best if the lead is long enough. Put the tester end on the input side of coil from switch, it should light up with switch in the run position. If you show voltage there, with tractor in neutral, put tester on the output side, and roll the engine over with the starter. Test light should flash. If it flashes, put the tester on the connection point on the distributor and turn over, you should see it flash. Doing that, you know your wiring is good to there. Remove the distributor cap and check the connection inside, you should still see if flashing when turning over. I have seen those Bakelite insulators crack, and short out on the distributor case.
If you have voltage to there, turn the switch off for a moment. Rotate engine until points touch. Turn switch on, and break/separate the points manually with a small screwdriver, you should see a small spark when the points separate. If you see a spark, look closely at the points, especially the rub block. The lesser expensive contact points set's rub blocks can wear, bend, or completely come off. The one on my TO35 Ferguson was completely gone. Friends of mine literally gave me this tractor and several attachments just to get it out of their yard. They got frustrated after piddling with it, and just wanted it gone. A new points & condenser kit, new plugs, purged/cleaned the fuel system, and a good carb cleaning, and it fired right up. A few more issues to deal with when I get time but should be a good useable tractor once time allows to look into those.
If you have voltage to inside the distributor, I'd have to guess it's the condenser. Some simple diagnostics like this can save you a lot of money just throwing parts at it.
If it does look like the condenser is the issue after this diagnostic test, do you think a spare condenser from my Ford 8n would work on the Farmall cub ? Both tractors are similar vintage positive ground 6 volt with 4 cylinder engines.
I’m hoping that’s the case, because I have several of those in my parts cabinet. It’s going to be tough and/or expensive to get a “proper” coil on that Farmall, if the coil turns out to be the issue.
/ 6 volt coil question #25
Battery ignition systems usually use a condenser rated .20 to .28 microfarads, so you should be OK if you can get it stuffed in there.
No luck with it today. Now I have about 3 hours into it plus the $34 NAPA coil, so I’ve reached my limit on time and parts for the “do it myself” attempt.
I’m going to give my Farnall mechanic buddy a call and see if he’ll let me borrow his trailer and if he has time to work on it. If you so, I’ll winch it on his trailer, and haul it over to his place. I’m in no hurry for it, and it will be nice to free up the barn space here.
While he has it, I’ll get him to do an oil and filter change and lubricate the throw out bearing. That’s a pain to get at. Hopefully, I’ll get another 2 or 3 trouble free years out of it, after that.
I did manage to make a new bracket for it to take the standard NAPA 6 volt coil. I’ll keep the OEM one, in case my buddy wants to put that one back on it, or if I ever blow the NAPA one.
My diagnostic check showed power to the input side of the coil, with the switch on run, but the test light did not flash on the output side. It glowed steady but dimmer than it did on the input side. That’s why I decided to try the new coil. Still no go though.
Next, I’ll take the snowplow, drawbar weight, and rear tire chains off of the Cub, and get it ready to trailer away. After that, I’ll start working on the old Ford. Hopefully, a NAPA coil will do the trick on that one.
My dad gave me his old Shopsmith last fall and it worked pretty good, with an end mill, to make the new coil bracket base from a piece of brass. I’ve never been much of a woodworker, but I used to use it a lot when I was living at home as a kid, for various metal projects.
I towed the dead Cub up the the front of the barn today, to get it ready for transport to our local Farmall specialist. I’ve got to strip off the rear chains, snowplow, and drawbar weight.
I’m going to run that drawbar weight on the front of my dad’s 2wd JD 770 this summer. Hopefully, that will be enough to hold down the front axle so I can haul more firewood with the 3 pt carryall and not do so many wheelees with his 5 ft bushhog on that.
Hopefully, all that Cub needs is points and a condenser. I’ll ask him to lube up the throw out bearing while he has it over there. I guess I can do the oil and filter change when I get it back.
/ 6 volt coil question #30
My 8N ford was converted to 12 volts over 30 years ago by myself.
About 5 years ago I suspected the original coil was bad because after the engine got warm it wouldn’t run very well so I bought a new coil from the local Advance Auto store, cost about $50 , probably made in China or Mexico I really don't know or care it has a lifetime warranty.
My 8N Ford starts better now than it ever did in all the 55+ years I have operated it.
/ 6 volt coil question #31
I changed my 1950 8N to 12 volt. I had problem with points on that until I figured out it was a worn bushing in the distributor. I replaced that and at the same time I changed to the solid state points replacement. That hasn't failed in close to 20 years now, always starts when cold as it is my snow plowing tractor.
Bill
Bill
My still 6 volt Ford 8n has been down and out since last summer, also with an undiagnosed “no spark” issue. I’m going to push that into a corner of my barn, maybe for 5 or so years, when I retire from my day job.
No real need for it now, and it’s plenty hard for me to keep one of those off-brand gas tractors running, with the limited free time I have now.
I wouldn’t dream of converting a 6 volt tractor to 12 volts or buying one again, that’s had that done to it. Too often, folks do that to make up for weak compression
When the Ford 8n and Farnall Cub, that I have now did run, they both ran real good. Someday, I hope they do again. I’m confident that the farnall will, because my buddy is real good with them. Not so sure about Ford though. That may end up a hedge row ornament.
/ 6 volt coil question #33
Hey, curious what the final diagnosis was on the Cub? My 240 Utility (also 6v pos gnd) did exactly the same thing. Was running well, shut off like the switch turned off. Had a loose wire cause the problem before. Traced the ignition through the coil to the plugs, all good. Still no start. Thinking i may either have a points issue or a weak coil.
/ 6 volt coil question #35
If I read those last few sentences right, you have spark at the plugs although it may be weak. First thing I'd check is to look inside the distributor cap. They can get a build up on them like a carbon type deposit from ionization on the lugs, aluminum one's seems to be worse at it. This can be scraped off with your knife and get you by for a while. I actually got by with it on my one Super C for nearly 20 years, just to see how long I could get by with it. Cap finally cracked causing a backfire jumping across to the wrong lug inside causing a backfire. Replaced the cap and everything was fine.
I'd definitely check the points. Sometimes they can get burned or get a little teat on them. You may get a weak spark, but not enough to run. And again, check the rub block they can wear or roll under seemingly from if the grease was put on the rub block can soften them and cause them to wear off, or roll under. You can lightly dress the points with a small file, then re-gap them to the proper .020. They probably won't last long if burned because the tungsten coating has burned through.
/ 6 volt coil question #36
Sometimes polishing with a clean business card between the closed points was all that was needed to get going after a long layup…
I’ve never gone with one of the kits to replace points but friends really like these and no more points to wear out/replace.
/ 6 volt coil question #37
Both of our 8N's are converted, excellent use for old batteries that no longer start engines with 12 volt starters but are not completely dead.
One of them has a 12 volt battery removed from vehicle service 5 years ago in March.
Beats just getting a $10 core fee for a battery that can still be useful for years. Especially when 6 volt batteries cost more than 12 volt ones these days.
/ 6 volt coil question #38
And when we got the '48, I learned how much of a pain it was to get to the front mount distributor.
This is a trick my Father showed me to get them running without actually having to get inside the distributor.
That trick has saved lots of hours over the years. AC power cleans the contacts, DC does not.
/ 6 volt coil question #39
Interesting… first time I’ve seen this.
/ 6 volt coil question #40
If you do not understand the dangers of AC power the method should be avoided. The bulb is the load for the 60 Hz AC power to blow the oxide off the contacts.
My Fathers drawing below shows using wall power but we don't have power in that barn so I used the generator that day.
Must use the neutral to the chassis, if you have not confirmed this, to the end of the line (if you add an extension cord check at the end of it) you put yourself at risk of electrical shock. Because you will have the tractor at 120v ac.
A plug tester can confirm this, I didn't have one that day, so I never touched the tractor "plugged in", except with the wood handle to crank it over.
A 12v dc/120v ac inverter plugged into the lighter outlet is what I use these days. Stays in the storage of that mule.
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2016 Chevrolet Express 2500 Cargo Van (A64556)
2016 Chevrolet...
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
