What did you buy this week?
   / What did you buy this week? #1,801
"I got 8." You sound just like me. We're going to live to be 250yo aren't we?
   / What did you buy this week? #1,802
We better ! That's about the break even point for me burning wood !
   / What did you buy this week? #1,803
I'll be surprised to see the bottom side of 80.
Going to install 6 immediately.
   / What did you buy this week? #1,804
I got myself a new Kubota RTV-X1100c with the snow blower......it was delivered right after the snow melted...lol. I did get to check out the blower and it is amazing!!! It will do a great job this spring, summer and fall hauling and dumping sand & stone.
   / What did you buy this week? #1,805
With a huge stack of kiln dried sawmill wood in the 2" thick by 12" wide variety in my shop it was blatantly obvious my little table top Dewalt planer was not up to the task. So I poured over FB Marketplace until I found what I was looking for, an old school 15" 220v planer. I found a Delta DC-380 for $600 which is WAY cheaper than anything else I was seeing. You should have seen the rusted out planers on there for $800-$1200. For $600 if I decide it is too big for my shop I can easily get my money back out of it and maybe make some money on it. But honestly anyone who owns a sawmill should also own a capable planer ike this, so chances are I will keep it. Got new blades coming, while I wait I am going to clean it up and adjust some things. Looking forward to seeing what this thing can do. Also this finally gives me a reason to do a 220v outlet in my shop. I plan on wiring a drop cord style outlet out of the breaker box for now. That way I can use it over by the wood working stuff but also pull it outside to weld things with the stick welder.
   / What did you buy this week? #1,806
With a huge stack of kiln dried sawmill wood in the 2" thick by 12" wide variety in my shop it was blatantly obvious my little table top Dewalt planer was not up to the task. So I poured over FB Marketplace until I found what I was looking for, an old school 15" 220v planer. I found a Delta DC-380 for $600 which is WAY cheaper than anything else I was seeing. You should have seen the rusted out planers on there for $800-$1200. For that price if I decide it is too big for my shop I can easily get my money back out of it and maybe make some money on it. But honestly anyone who owns a sawmill should also own a capable planer ike this, so chances are I will keep it. Got new blades coming, while I wait I am going to clean it up and adjust some things. Looking forward to seeing what this thing can do. Also this finally gives me a reason to do a 220v outlet in my shop. I plan on wiring a drop cord style outlet out of the breaker box for now. That way I can use it over by the wood working stuff but also pull it outside to weld things with the stick welder.View attachment 3025088
If that planer is an earlier model 380 made in Brazil, they are a pretty good planer, if it's a later one made in china, then not so much.
SR
I think these Merrell shoes from Amazon are one of the best values in shoes. I've probably gone through 10 pair so far. Depending on the color you get, they are priced very well. VERY Comfortable and pretty rugged shoes. I have not torn up a pair yet, though I'm big and usually the soles finally start to support me less and I replace them.
   / What did you buy this week? #1,808
Nice to be able to buy new! Our 1100c rides much better than our old RTV-900.
   / What did you buy this week? #1,809
Got a Yankum rope recovery kit. Last storm dumped on a layer of ice, had several guys hung get hung up. Friend yanked out a one ton , plow and sander that was over a bank with no drama with one. Little spendy but a lot safer than the old wire rope that has seen better days that I've been using.
Watched their video.
That appears it can be very hard on suspension of towed vehicle.
I have a 3" wide woven nylon strap rated for 20,000# with hooks on each end. It gives some, but nothing drastic like the video shows.
   / What did you buy this week? #1,810
The "give" in the kinetic roads is what cushions the jolt to both vehicles and suspensions.
The flat straps with hooks don't provide near the advantage the stretch ropes do.
I grew up with chains and wire cables, then tried the straps (never really cared for them) and now the ropes, the ropes are much better and easier on the equipment.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Kubota L2500D Utility Loader Tractor (A55851)
Kubota L2500D...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
