Questions about 2013 Massey Ferguson 1533 Rear Remote install
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #41
Where is the brand and model number located on it. Everything the dealer sends me a diagram on it. It's the wrong part
I have no way of knowing but there must be a nameplate or sticker or some indication of the brand (and model surely) on the body of the loader valve.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #42
Are you talking about this plug? Thus picture is from the top side of the last picture you posted.
That’s the sump port for the third hose. I couldn’t see it in your other photo. So you have all 3 ports identified 👍🏻
It’s not the hex plug that gets replaced with a diverter plug, that I mentioned though. That should be directly on top of the return port casting, pointing downward
It’s not the hex plug that gets replaced with a diverter plug, that I mentioned though. That should be directly on top of the return port casting, pointing dodownward
Here is what I believe you are talking about circled in red. It's a hex capped pointing downward. The white is the return line flush allen head port.
Do I need a diverter plug in it if I'm not using it in a "rear remotes" setup and just using it as a "power beyond" style?
OK so if I understand the diverter plugs purpose. The cap that is there should alow for flow to that plug. (And give me power beyond, or "constant pressure") If I use a diverter plug it would be for a "third function" and would shut off the use of 1 of the loader functions. And diverter it to the 3rd function until I swap it back.
I also have these 2 I could hook up and use as a "3rd function" control.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #46
That looks like the one
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #47
As I previously mentioned, I don’t know how the machine would operate without it. I don’t recall its exact shape either, so I don’t know if it’s actually diverting return flow from passageways internally vertically or horizontally for some reason , or if it’s only for restricting flow. I doubt you can buy it, and I doubt anyone has a dimensional diagram of it either.
Thanks again for all the information and help with this thread. I appreciate it.
Thank you everyone for your input, information and help throughout this thread. I understand there is alot of parts diagrams out there. But why are there so many instances where even the diagrams the dealership sends me are of the wrong parts? Is it a tractor thing? An older not on the assembly line tractor thing? MF thing? Do they just do like they used to with 70-80s jeeps and when one part runs out they just pull out whatever is laying around on the shelf?
It was easier for me to find what I needed to swap a 12V cummins, get an adapter for a ZF5 and swap it into an 08 F350 that originally have a 6.4 powerstroke, than it was/is to figure out how to install a power beyond on a 2013 tractor. (Technically I still haven't used it yet to make sure it works.) Haha this was so much more confusing than I thought it would be.
   / Questions about 2013 Massey Ferguson 1533 Rear Remote install #50
Massey Ferguson 451 has a square steel plate behind the seat to which the valve body and 2 pressure and return hydraulic connections are mounted.
I'd expect any MF dealer can order the plate w/ fittings and valves. Personally I'd mount it somewhere else. Behind the seat makes it inconvenient for hooking up 3-pt implements.
You can see it in this picture if you blow it up,
Jisan Heavy Duty CAT345 72in Excavator Bucket (New/Unused) (A59225)
Jisan Heavy Duty...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
KIOTI SL7504-PL SKID STEER (A52709)
KIOTI SL7504-PL...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
