How does a NOCO battery charger "desulfate" the battery?
   / How does a NOCO battery charger "desulfate" the battery?
Thank you for all the replies. So, it looks like I just hook up my battery to charge it and the desulfate action automatically happens?
   / How does a NOCO battery charger "desulfate" the battery? #22
If your battery is completely dead I hook up jumper cables and hook it to a running truck for a few minutes.
Some newer chargers will give a Bad Battery light if there is 0 voltage.
I recently saved three battery's with the desulfate mode that I thought they were dead forever.
I figure my new $300 battery charger has paid itself off. It works
I know guys that have done that. I've learned to charge batteries late winter and spring and whenever they don't get used much to keep a charge up. It's not uncommon that I have a battery go 10 or more years when I use my NOCO chargers.
   / How does a NOCO battery charger "desulfate" the battery? #24
NOCO has a force charge mode. It will charge even if the battery is 0%. You just need to press the button for 6 seconds to enter this mode.
   / How does a NOCO battery charger "desulfate" the battery? #25
I'll see if holding that button down for six seconds for a dead battery.
I do need to maintain my battery's better.
They don't like setting for long periods. Especially with ecm's that draw juice slowly.
Parisitic draw.
   / How does a NOCO battery charger "desulfate" the battery? #26
This whole thing about desulfating a flooded lead acid battery has always intrigued me. Surely you have removed the caps of and old FLA battery and seen the difference between it and a fresh, new one. I am on the fence as to whether a sulfated battery can be restored or not, regardless of claims. For the record I have a bunch of BatteryMinder maintenance chargers and use them regularly on EVERYTHING.
One thing that can be truthfully stated is that the best way to avoid sulfation and to get maximum life is to keep the FLA battery fully charged without overcharging it AND to USE it - as in a hefty load to no more than 50% SOC and a hefty recharge. Especially with deep cycle batteries. This is the best way to avoid sulfation in the first place. But ya know what? A FLA battery can not last forever even under the closest to perfect conditions. It has been designed as best as possible within economies but the battery still has a defined number of cycles. Period.
Lastly, your old battery is tired and won't hold up for use and fails a load test. It's been on a charger for days and days and ya still can't get the specific gravity up? Maybe there's a bunch of build up on the bottom and 1+ failed cells? It must be sulfated or shorted internally, right? Has anybody broke an old battery open to verify any of the above? I haven't. I haven't heard of anyone doing that either. Have you?
   / How does a NOCO battery charger "desulfate" the battery? #27
Reminds me of something I did many years back in my model building years. I had several small 6V lead acid batteries that I used in my model RC boats. They were used infrequently and after only 2 years, got to the point where they would no longer hold a charge. The battery cases were made of clear plastic and I could see white stuff covering the plates and black residue on the bottom. I didn't have much money back then and they cost too much for me to replace.
Being young and not knowing any better, I figured I could just clean them. I removed the cell caps, turned the batteries upside down in a pan and let the electrolyte drain overnight. I remember being surprised at all the crud that came out. I could still see the white coating on the plates though, so I got out the family Waterpik. I managed to get the nozzle through the fill hole and down between the plates of each cell. It took a little time but I managed to loosen and flush out most of, what I later found out was sulfation.
I took the batteries down to a local service station and for less than a buck, had them refilled with fresh electrolyte. The cleaning process actually worked! The batteries regained about 80% of their original capacity. I used this idea three more times and got more than 12 years of useful life out of them.
I don't think this would be practical with larger batteries though. It was the clear plastic which let me see what I was doing that made the process work.
   / How does a NOCO battery charger "desulfate" the battery? #28
When a battery is too far gone, there is just no recovering it. I have recovered several batteries (one of my own, two for friends) using the BatteryMINDer chargers when an ordinary, charger without the desulfation feature would not.
@JRH02 is absolutely correct: the best thing for a battery is to avoid sulfation forming in the first place. You can do their by keeping it fully charged. When the battery is discharged, even partially, the sooner to charge it back up, the better. (So when you bring that dump trailer with the deep cycle battery home after dumping a few loads, hook it right up to a good charger. Don't let it sit for a few days in that partially discharged state.)
   / How does a NOCO battery charger "desulfate" the battery? #29
I had a fairly new battery that sat in a seldom used pickup for several years, at some point it went dead, wouldn't start the truck and tested at 6.2 V.
My high dollar, state of the art hi frequency battery charge would start at 15.5 volt charge and within a few minuets turn red go to 0 volts and indicated bad battery.
I found my 1970 6 amp Sears charger, connected it overnight, the battery was fully charged next day.
Moved the battery to the tractor and it has worked just fine for over 2 years. The Sears charger has a 3 pound transformer, no smart electronics and is going to put out 14.3 volts whether the battery likes it or not. The old school charger served me well for over 35 years and and probably cost less than $50.
   / How does a NOCO battery charger "desulfate" the battery? #30
I don't have any idea how much more use that I'll get from the three batteries that the disulfate mode recovered on my charger. It's a bonus right now. I could have given them better lifetime maintenance.
I see using the disulfate mode as part of regular maintenance. A well-maintained battery builds up sulfates on the plates. I have had daily driver trucks that the battery was never ran low or dead that were full of built-up sulfate.
When I bought the new charger with disulfate mode I considered it was it used as part of a regular maintenance, not just to fix bad batteries.
It just so happens that I had three batteries that were dead from sitting and thought I would see what happen. It brought them back into use for now.
I have seen what is in the bottom of old batteries. My uncle melted down old batteries into fishing weights by cutting them open. Sometimes the bottom of the plates were stuck in the sulfate that had flaked off.
I think I remember being told that over the road trucks had the same sulfate buildup from running 24-7.
I don't think it's only an issue of poor maintenance. Although. I Am guilty of battery neglect. I'm old, years ago batteries were more durable. Now. Batteries are cheap but expensive and need TLC.:unsure:
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2014 Ford F-150...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Westfield Conveyor (A56438)
Westfield Conveyor...
