Can't get 2638 HST out of high range
/ Can't get 2638 HST out of high range #1
ibex276
Mahindra 2638
Tried everything to get it out of high range. Have had the tractor for 6 years. Always been hard to change from LMH but now is in H and can't change to medium or low. Thanks, if any knows the problem.
/ Can't get 2638 HST out of high range #2
I have a 2538 (same thing). Get on level ground and out of 4wd. Barely hit the fwd pedal and let off while jiggling the shift lever. Its stupid but works.
/ Can't get 2638 HST out of high range #3
This ▲ ▲ ▲
Might have to rinse and repeat several times, but it will work eventually.
I have been trying that but still stuck. Thanks. Will keep trying.
/ Can't get 2638 HST out of high range #5
Check the linkage joint under the seat deck. One time I discovered the nut was loose and it was "somewhat" easier to shift after I tighten it.
I jacked the tractor off the ground where all the wheels would spin. Loosened up the bolt that holds the
HMNL lever. Got a pry bar and got it out of H. Oiled everything. Got it all working better than ever. Still don't know why it was frozen up to start with but now it works. Thanks all.
/ Can't get 2638 HST out of high range #7
Good to hear you found a solution!
/ Can't get 2638 HST out of high range #8
It is common for the shift shafts that enter the case to rust up. A quick spritz once a year with your favorite penetrating lube will keep it working smoothly.
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Goosen Bale Chopper Hay Blower (A61166)
Goosen Bale...
Komatsu PC200 Excavator (A60352)
Komatsu PC200...
