battery charged but not cranking
   / battery charged but not cranking #1
bforr
Ford 1520 bought in 1984
1984 Ford 1520
cranked right up at the end of fall last year. battery dead now. charged it. checked it with a meter. Registered 12+ volts. turned the key and the glow plug lit up. Then nothing. Checked the battery connections. The negative was able to be twisted slightly so i tightened it. Still nothing. Checked the wiring at the starter. It registered just under 12v. Sometimes the glow plug lit sometimes not. Only once did it sound like the starter wanted to do something. I'm guessing the starter is bad. How do I test it? Any other ideas on what may be the problem?
   / battery charged but not cranking #2
1984 Ford 1520
Fully charged battery should read 12.6-12.7 volts. If less than 12 volts would suspect battery not up to snuff. Can you load test battery?
Ah. I'll check it out next weekend when i go back. Thanks for the reply.
   / battery charged but not cranking #4
Ya, i think battry is also shot. Also test battery voltage WHILE trying to start tractor. This will tell you if the battery is tryly shot
   / battery charged but not cranking #5
A depleted battery can more easily freeze than a charged one.
I didn't know to do that. Thanks.
   / battery charged but not cranking #7
You would need two people, one to watch the voltmeter attached to the battery, while the other turns the key, or a device that can engage the starter with push button similar as below:
   / battery charged but not cranking #8
As others had said, your battery's toast. I use the analogy take 8 1-1/2V D cell's hooked in series and measure the voltage, it'll be over 12V. The reason it won't turn over an engine is the available amperage, somewhat same deal with your tractor battery.
   / battery charged but not cranking #9
You said the cables were loose did you clean them before
tightening them??
willy
   / battery charged but not cranking #10
Before you condemn the battery, have you checked the ground cable where it bolts to the tractor? That's also a common problem with intermittent and/or poor starter response. Loosen the bolt, work the cable back and forth then tighten the bolt and try the starter again.
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2844 (A58376)
2844 (A58376)
Great Dane Van Trailer (A56436)
Great Dane Van...
Dodge Charger (A56859)
SCREENER (A58214)
SCREENER (A58214)
