Makita (Dolmar) Clutch drum parts help. EA 7300P
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
Looking for the best place to find a replacement clutch drum(sprocket)
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #2
The clutch drum part number is 957 223 092. Dolmar/Makita doesn't have a lot of aftermarket part following so may have to find OEM. If the drum isn't damaged should be able to just replace the rim
Ya bearing are good the teeth are not good anymore
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #5
Usually occurs with the rim is allowed to wear down past its usable point, and the chain drive links eat into the main spline housing.
It is a two piece and the sprocket disintegrated.
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #7
SLE equipment has them for a decent price, I've ordered from them before, they usually have decent prices on Dolmar/Makita parts.
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #8
Are you saying you just need the replaceable sprocket rim? Not a clutch drum the rim goes on?
If so only like 5 bucks and 3/8 7t standard aka large prob what you have on there.
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #10
correct thanks
Can get oem or aftermarket. Standard 3/8 7T about anywhere.
Just go to local dealer. There they might get you for 10-15 sometimes for oem ones.
Power Mate® Rim Sprocket System, 3/8" 7 Standard 7 Part# 26831​
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
2025 CATERPILLAR 255 SKID STEER (A60429)
2025 CATERPILLAR...
CAT 930M (A58214)
CAT 930M (A58214)
