y
Makita (Dolmar) Clutch drum parts help. EA 7300P
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
Looking for the best place to find a replacement clutch drum(sprocket)
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #2
The clutch drum part number is 957 223 092. Dolmar/Makita doesn't have a lot of aftermarket part following so may have to find OEM. If the drum isn't damaged should be able to just replace the rim
Ya bearing are good the teeth are not good anymore
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #5
Usually occurs with the rim is allowed to wear down past its usable point, and the chain drive links eat into the main spline housing.
It is a two piece and the sprocket disintegrated.
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #7
SLE equipment has them for a decent price, I've ordered from them before, they usually have decent prices on Dolmar/Makita parts.
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #8
Are you saying you just need the replaceable sprocket rim? Not a clutch drum the rim goes on?
If so only like 5 bucks and 3/8 7t standard aka large prob what you have on there.
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #10
correct thanks
Can get oem or aftermarket. Standard 3/8 7T about anywhere.
Just go to local dealer. There they might get you for 10-15 sometimes for oem ones.
Power Mate® Rim Sprocket System, 3/8" 7 Standard 7 Part# 26831​
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #11
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #12
There are three common spline sizes for the drive sprockets: Mini, small, and standard. To tell the difference:
Mini: Approx 5/8" ID
Small: Approx 3/4" ID (penny fits inside, a nickle does not)
Standard: Approx 7/8" ID (nickle fits inside with room to spare)
   / Makita (Dolmar) Clutch drum parts help. EA 7300P #13
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
(18) 10'-6" PVC CONDUIT PIPE (A60432)
(18) 10'-6" PVC...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
