Parts availability for Bolens/Iseki
   / Parts availability for Bolens/Iseki #1
Capricious
Eastern Missouri
Mitsubishi MT160D
Good evening: Opinions on the parts availability situation for Bolens/Iseki? And also sources of paperwork (service manual, parts diagram) Looking at what is supposed to be a Bolens 1704, although the information I have found says that this should be a hydrostat, while the tractor itself is a gear tractor. Had a Mitsubishi tractor a while back and parts were a bit difficult to get for that. Here I am looking at another orphan. Thanks.
   / Parts availability for Bolens/Iseki #2
Iseki was good at giving multiple designations. The TX1704/g174/2160 was a gear drive. The H174/H1704 was a hydro. I have manuals for both models. I can supply engine, clutch & most fwd parts. Transmission parts some are available. Can't tell which until someone inquires about them. .
   / Parts availability for Bolens/Iseki #3
ii have a hs1502 bolens which seems to have a fuel leak around the injector pump fittings, are the seals an o-ring?
   / Parts availability for Bolens/Iseki #4
There’s 2 places they can leak from..& yes, they are orings and a copper delivery valve gasket..
The orings and gskt are specific to the manufacturer..
I can handle that for you..
Feel free to contact me directly, either thru a prvt msg or email..
   / Parts availability for Bolens/Iseki #5
Tag. I have 2 Bolens/Iseki tractors. One is a 1984 model, the other a 1989. They have been great but always good to have another source for parts in the back pocket!
   / Parts availability for Bolens/Iseki #6
I'm loking for a parts diagram for the Bolens H1704 hydrostatic tractor that I have but can't seem to find 1 anywhere online can someone help me find 1.
   / Parts availability for Bolens/Iseki #7
I can supply manuals & parts. email me
   / Parts availability for Bolens/Iseki #8
--- +++ === F R E E === +++ ---
BOLENS manuals
Bolens Manuals
   / Parts availability for Bolens/Iseki #9
Hi Lens12, greetings from Australia. I’m chasing a drive set, pinion and gear ring, for a Bolens Iseki G174 front differential. Parts manual lists it as 187-1481. Can you help at all? Struggling to source it from suppliers.
   / Parts availability for Bolens/Iseki #10
Just email them at parts@sheaftractor.net
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
