Parts availability for Bolens/Iseki
   / Parts availability for Bolens/Iseki #1
Capricious
Platinum Member
Eastern Missouri
Mitsubishi MT160D
Good evening: Opinions on the parts availability situation for Bolens/Iseki? And also sources of paperwork (service manual, parts diagram) Looking at what is supposed to be a Bolens 1704, although the information I have found says that this should be a hydrostat, while the tractor itself is a gear tractor. Had a Mitsubishi tractor a while back and parts were a bit difficult to get for that. Here I am looking at another orphan. Thanks.
   / Parts availability for Bolens/Iseki #2
Iseki was good at giving multiple designations. The TX1704/g174/2160 was a gear drive. The H174/H1704 was a hydro. I have manuals for both models. I can supply engine, clutch & most fwd parts. Transmission parts some are available. Can't tell which until someone inquires about them. .
   / Parts availability for Bolens/Iseki #3
ii have a hs1502 bolens which seems to have a fuel leak around the injector pump fittings, are the seals an o-ring?
   / Parts availability for Bolens/Iseki #4
There’s 2 places they can leak from..& yes, they are orings and a copper delivery valve gasket..
The orings and gskt are specific to the manufacturer..
I can handle that for you..
Feel free to contact me directly, either thru a prvt msg or email..
   / Parts availability for Bolens/Iseki #5
Tag. I have 2 Bolens/Iseki tractors. One is a 1984 model, the other a 1989. They have been great but always good to have another source for parts in the back pocket!
   / Parts availability for Bolens/Iseki #6
I'm loking for a parts diagram for the Bolens H1704 hydrostatic tractor that I have but can't seem to find 1 anywhere online can someone help me find 1.
   / Parts availability for Bolens/Iseki #7
I can supply manuals & parts. email me
   / Parts availability for Bolens/Iseki #8
--- +++ === F R E E === +++ ---
BOLENS manuals
Bolens Manuals
   / Parts availability for Bolens/Iseki #9
Hi Lens12, greetings from Australia. I’m chasing a drive set, pinion and gear ring, for a Bolens Iseki G174 front differential. Parts manual lists it as 187-1481. Can you help at all? Struggling to source it from suppliers.
   / Parts availability for Bolens/Iseki #10
Just email them at parts@sheaftractor.net
2009 FORD F-250 SUPER DUTY (A48992)
2009 FORD F-250...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45679)
2016 FREIGHTLINER...
All Aluminum Service Body (A49251)
All Aluminum...
WHEEL LOADER BUCKET (A46683)
WHEEL LOADER...
Stump Grapple (A49251)
Zimmerman 12 Ton Tandem Gear (A49251)
Zimmerman 12 Ton...
