Bercomac snowblower problem
/ Bercomac snowblower problem #1
tundraman01
Member
I have 72" Bercomac, model #700969-1-33v with the 33hp B&S mounted on a tractor. B&S engine is running, second stage is spinning augers are not. The shaft from the second stage to the gearbox that drives the augers is spinning. I can spin the augers freely. Both move together. All three shear pins are fine. It appears something is disconnected in the gearbox. Anybody know what I should inspect/expect if I open the gearbox? Any ideas on what could be wrong? There doesn't feel like there's any grinding or binding going on.
I'm not sure if this is the best spot for this question, please redirect me if there is a better forum for it.
I took it apart today. The input shaft is sheared in two right behind the worm gear. Thankfully all the gears look ok.
/ Bercomac snowblower problem #3
UGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You need an entire replacement cross auger and gearbox with the 3 shafts and bearings that come with it.
This nasty item is part number 2 on page 36 of the owners manual.
I hope you are within their one year warranty period.
:^0
UGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
/ Bercomac snowblower problem #4
Hardox steel would cost
Curious as to what Hardox steel is, is that similar to a hardon?
Never heard of Hardox, sounds like a trade name. You want shafting drawn from alloy steel that is shock resistant and machinable. Consult a Machinery's Handbook for the correct grade and it won't be 'Hardox' whatever that is....
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
