What bolts for the front hydraulic pump adapter plate to crankshaft on MF-50?
/ What bolts for the front hydraulic pump adapter plate to crankshaft on MF-50? #1
dwildey
MF-50
Hello,
I'm adding a MF-101 Loader to my MF-50. I ordered the pulley below and my crank pulley has what appears to be three holes with 3/8" threads. What bolts are supposed to be used? The bushings in the pulley I ordered are much larger (probably 1/2"). I've looked for shoulder bolts or other bushings, but can't find anything to work.
Maybe I need a different crank pulley? IDK. Any feedback would be a appreciated.
/ What bolts for the front hydraulic pump adapter plate to crankshaft on MF-50? #2
Hello,
I found this on Steiner Tractor Parts on page 622 part no.MFS3746 list price $68.76 Description front hydraulic pump adapter plate ( all using 3 boltfront pump drive ) ( 3/4"-10 UNC LH thread, 5.250" O.D., 3 bushings w/ mounting holes3.465" on center, 4" bolt circle ) The website is www.SteinerTractor.com Or You can call them at 1-800-234-3280 This part looks identical too yours. I hope this was helpful, & welcome to TBN. I do own a 1959 M-F 50 gasser IMHO they are great tractors.
Thank you! I checked my crank and they are 3/8-16 UNC RH and it lines up, but bushings are 1/2" and bolts are 3/8".
I use to have a 9n and I love the M-50 with power steering. It's so much more of a tractor. Here's a pic of mine and the loader I'm adding.
/ What bolts for the front hydraulic pump adapter plate to crankshaft on MF-50? #4
Very nice M-F 50 looks like You did allot of work to her. I'm hoping too do a respray on mine this year hard to do when your doing work with the tractor most of the time. Here is a picture of my 50 working with my newer 2018 M-F 1526, & dump truck. Sorry I couldn't help You.IMG_20201003_134009.jpg
Just an update if anyone else needs help. I used Tee-Nuts from Tractor supply which worked perfectly to take the play out of bolt going through pulley spacers.
/ What bolts for the front hydraulic pump adapter plate to crankshaft on MF-50? #6
Thanks for the update it's good to hear You found what You were looking for; I go there pretty often, & would have never thought to look there.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2001 Ford F-650 18ft Rollback Truck (A61568)
2001 Ford F-650...
2018 Nissan Sentra Sedan (A61569)
2018 Nissan Sentra...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
