Battery size for my Ford Jubilee recomendation
/ Battery size for my Ford Jubilee recomendation #1
tractorboy924
Looking to see what rated battery CCAs is suggested for my '53 Ford Jubilee... Im not sure if the old one is right...it works dont get me wrong but what is called for in that machine?? Want to make sure I get a properly sized battery when I replace it here soon..........
/ Battery size for my Ford Jubilee recomendation #2
Has your tractor been upgraded from 6 volts to 12?
/ Battery size for my Ford Jubilee recomendation #3
Regardless of voltage I'd be prone to measure the battery box and get the biggest one that would fit. Remember to check the height for the terminals and their configuration so cables will be long enough.
/ Battery size for my Ford Jubilee recomendation #4
Yup. That's what I would do. Mine even stuck out thr side a bit.
/ Battery size for my Ford Jubilee recomendation #5
meh, you'd be surprised what you can get away with... I've seen a Ford 9000 run for many hours over a few weeks with a non functioning charging system on a standard deep cycle/marine battery instead of the giant semi sized battery it's supposed to have... when it stops starting jump start it and take the battery off and charge it for next time lol...
/ Battery size for my Ford Jubilee recomendation #6
I think it called for an 80AH battery, but, like Roadworthy said, you can't have too much battery.
2017 Thompson 32HPU 55kW Towable Pump (A59228)
2017 Thompson...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61306)
PENDING SELLER...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
ROSCO SPREADER (A59823)
ROSCO SPREADER...
