FX24D Won't Start
/ FX24D Won't Start #1
Mal Kelly
Yanmar FX24D
Help me get my tractor going again! I have a FX24D that has acquired a gremlin. Had the side covers removed and when I started there was a spark from the right side of the engine compartment, I turned the tractor off and went looking for the culprit and found nothing. Re-started the tractor and did some work. Next day tractor would not start. Searched again and found a nylon plug with a black and a yellow wire attached to it but could not find anywhere it came from. Removed the bonnet assembly for a better look and still could not find anywhere to attach the plug. Am currently assuming this plug is a red herring and is not in use??? Tried starting the tractor again, both oil and charge lights come on, turned the key to start and the only thing that happened was the two lights went out, no solenoid click or anything. Turned key off and then on again now no lights and no start. A few hours later tried again and lights and then nothing when going to start and everything dead again. Any ideas I can't seem to find a detailed wiring diagram anywhere on the web to assist me.
/ FX24D Won't Start #2
Does the Battery have 12V. showing. Still doesn't say it's good but you know you have good power. Then check all the connections to it. + /- I'm guessing ground to the battery or were the cable connects to the frame if you show good voltage. Connections to the starter etc...
/ FX24D Won't Start #3
The electrical schematic is this,
(click on it to make larger)
QUESTION, how thick is the wire? IF it is thick, then does it go to the starter?
/ FX24D Won't Start #4
On the YTOG, we have a close manual for the tractor family you own of the FX24,
YANMAR F20 FX20 PARTS MANUAL NPC-1561.pdf
If you can find this, you would be in good shape,
/ FX24D Won't Start #5
Measure battery voltage - should be 12.6 volts or so. Keeping voltmeter on battery have someone attempt to start while watching voltmeter. It will drop but should not go below 10 volts or so. If it does drop lower you have a bad battery or charger issues. If it does not drop clean terminals and connectors. Replace connectors and tighten securely. Don't forget to clean and tighten the chassis ground.
/ FX24D Won't Start #6
Electrical parts either work or go bad and don't. For it to start and if the battery had a full charge on it and dead the next morning is normal for a bad battery. Cold and winter for that to happen is typical. Check the Battery is good before you try to start it.
/ FX24D Won't Start #7
I think the spark you saw is telling. As careyo63 suggested I think it is a ground to frame connection.
Eric
/ FX24D Won't Start
Well, what a silly billy! Replaced the battery a couple of months back and to squeeze it in I had to remove the earth strap out of the way. Obviously, I hadn't tightened the stud well enough, and it came loose. All fixed now and thanks for sharpening my mind, I guess that odd wire described above made me look for a more complex problem instead of the obvious, I must be getting old. Thanks again for waking me up to the obvious. Oh, and if anyone ever thinks of what that pair of wires might be let me know.
/ FX24D Won't Start #9
Glad that you found the fix yourself!
I would try the schematic as a way to figure out what the mystery plug is, and then try tracing the wires from the connector.
All the best,
Peter
/ FX24D Won't Start
I've tried referring to the schematic but as it is Japanese it hasn't been of much help. The mystery plug has two wires going into it, one black and one yellow. These wires are taped and go over the engine to the left where they join two more wires that go to the temperature sensor. All four wires are then taped and disappear into the main loom. The plug itself has nowhere within its reach that it can attach to so I'm assuming the loom is common to two different models, but this plug is not used on the FX24D.
/ FX24D Won't Start #11
Had to dig it up but I think this should be the same. On a YM336 Dia. Pto Switch?
  • Yanmar 336 wiring diagram0001.pdf
/ FX24D Won't Start
Thanks, mate I'll see if I can chase this down from the diagram you have supplied. Looks very similar to the one for the FX24D but at least it's in English which should be a great help/
/ FX24D Won't Start #13
You might have a look at the back of the dash. The only item that I see in the above schematic with black and yellow on it is the charging lamp. Given where you found it, I would be thinking something more like the thermostat connector or PTO control.
All the best,
Peter
2022 EZ-GO ELITE...
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A65563)
2002 Ford F-550...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
Case skid steer wheels and tires (A63689)
Case skid steer...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
