Going to try my hand at gathering sap
/ Going to try my hand at gathering sap #11
This will be my forty sixth season boiling maple sap but with getting old I'm down to around 460 buckets. Instead of trying to make syrup yourself with no experience, why don't you volunteer your labour to a local sugarmaker to give you a chance to learn how it is done? You might find that all the work involved is not worth it to you to make your own syrup.
/ Going to try my hand at gathering sap #12
My property up north has an old shack that was used to boil maple syrup down and was built in 1940. So I figure why not try to continue the tradition. I bought a beginner tapping kit off Amazon that comes with bags, tubing and the spouts. The bags are 5L so I hope that is enough to not overflow in a week, because I can pretty much only head up on weekends due to that annoying job I have. Figure I’ll set maybe 4 or 5 on a Sunday and head up next the Saturday to check. Then I guess I’ll boil them down over an open fire in my Stainless steel 8 gallon pot I used to use to brew beer. That’s the plan anyway. I’ve never done it before so should be a learning experience. Any tips appreciated.
Your in for a shock. Had to look it up. 5L is 1.3 gallons. On a good run those will be running over several hours. Gathering once a week. BAD IDEA. Sap goes bad and needs to be collected daily if it is running. If you can only do it on weekends then hang them the day before. Sap runs above 35 and needs freezing temperatures to continue. There are years that sugaring goes for months and years that it ends the same week it began. For our area there is the potential for it to be one of our best years due to long cold winter. On that same token we could break this weather and see steady 40-60's and the season won't make it a week. It is looking like we won't start tapping until March this year. I help my uncle with his setup. Only 130+- buckets and a 4x8? evaporator Sure is different from the 5x14 when dad and uncle did syrup.
Uncle setup
The good old days of sugaring. Lots of memories. Did about 2000 taps. Mostly buckets some tubing.
Questions, I should have an answer
Thanks all for the input. I’m going to modify my plan based off your suggestions. I think I’ll just take a week off and start small scale maybe 2 trees. Then I can monitor the flow and get things rolling. Always looking for an excuse to head up there anyway :). Once I’m up there full time I can go larger scale but for now it’s to learn the process and share it with my twin girls.
/ Going to try my hand at gathering sap #14
What happens when the syrup goes bad? Does it taste sour or just plain spoiled? Does it make you sick? I have been thinking about trying to make alder syrup and maybe tapping a couple maple trees we have. Living north of Seattle we of course don't have the trees for syrup like the northeast does. Not generally the weather either. But I have heard about alder syrup and thought it might be fun to spend a weekend tapping and boiling. To get maybe a cup of syrup.
Eric
/ Going to try my hand at gathering sap #15
I have tasted Hickory syrup. I am guessing its the same idea/process. ?? Anyone ever tried that? Wonder how far down south it could be done?
/ Going to try my hand at gathering sap #16
Eric
Yes, it's sour just like milk.
/ Going to try my hand at gathering sap #18
Alder sap? That doesn't sound great tasting, but if it works for, go for it.
I've tasted birch sap; wintergreen overtones. IIRC, it took a lot more birch sap to get it down to a syrup, due to the lower sugar content.
All the best,
Peter
/ Going to try my hand at gathering sap #19
If the syrup has been boiled to the correct sugar content and is packaged (canned) properly it should last years just sitting unopened on a shelf although the taste does fade over time. Maple sap, on the other hand, goes acidic relatively quickly and eventually turns to vinegar. The traditional method to clean the back pan of the evaporator at the end of the season, which I use, is to fill it with sap and let it sit until July or August at which time the smell of vinegar is strong. After emptying it, some scrubbing and then rinsing bring the stainless steel back to being as shiny and clean as new.
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
EXCAVATOR COUPLER (A60736)
EXCAVATOR COUPLER...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2021 New Holland Powerstar 110 (A60462)
2021 New Holland...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
