Can the hydraulic system get air locked after a fluid change
   / Can the hydraulic system get air locked after a fluid change
I do know a guy that works for CAT. I wasn't sure if a diesel mechanic would be familiar with hydrostatic transmission.I will have to give him a call.I'll let you know how I make out. Thanks Len
   / Can the hydraulic system get air locked after a fluid change #62
I think that if you tell him the type of transmission or show a picture of a cutaway HST he he can figure out it out. It is just one swash plate hydraulic pump driving another. Lots of hydraulic systems are similar to that.
Frankly, to me it didn't sound like an internal transmission problem at the start - though it might have gotten to that later.
It sounds like at the start either a control cable or more likely the hydraulic fluid is not getting to the transmission. If a good mechanic can't find the problem in a couple of hours then it can go to the dealer.
I've forgotten if we have a good schematic of your ck hydraulic system on this thread, but that would be a help to him as well.
rScotty
   / Can the hydraulic system get air locked after a fluid change #63
Is this the same thread where original poster asked about input shaft into the transaxle turning when trying to move the tractor? If yes after looking parts breakdown he could have fully functional hydraulics and transaxle not work if input shaft is not spinning or splines on input shaft are shot so shaft is turning but HST pump is not.
   / Can the hydraulic system get air locked after a fluid change #64
If we recall, Len did state that the tractor felt a little wonky even before the fluid change.
Don’t know too much about his tractor age wise, used or new or any previous problems or over worked situations encountered.
The simple things such as air entrainment or suction leaks seemed to have been addressed.
I am wondering if the
pump is still making any noise or if the problem is related toward a pressure relief valve.
As Scotty has mentioned, there is an inclination of wanting this tractor before me so as to rip into it .
Can only wish the best for Len.
   / Can the hydraulic system get air locked after a fluid change #65
That's right. Tractors often have several hydraulic pumps for different systems, and each can be fed in a variety of ways. So it is entirely possible for a FEL/3pt to work just fine while a HST doesn't move the tractor at all. Power steering is a world all of its own. Even PTOs can be fully hydraulic or hydraulically actuated. Sometimes - but not always - one part of a hydraulic system can affects the rest of the system too.
Half the problem here is we don't know the system. A mechanic often needs the work shop manual with its hydraulic flow diagram and hydraulic schematics in order to diagnose all but the simplest problems.
But the other half of the story is that given the flow diagrams - plus a pressure gauge with some fittings -finding a hydraulic problem suddenly becomes enjoyable mechanical work.
rScotty
I'm posting some schematics . I have pages of diagrams on all the transmission components.
My tractor is a 2006 ck 25 kioti
   / Can the hydraulic system get air locked after a fluid change #68
Those diagrams are great. Did you ever replace that hose and clamps back on Feb. 1?
Are you still trying to do this yourself or going to find some mechanical help?
I did change hose and clamp. I'm waiting to hear from a diesel mechanic . Hoping he will be able to come take a look. The nearest dealer with a real mechanic is 2 hrs away. That will be the next move if I can't get someone to come here to look at it.
   / Can the hydraulic system get air locked after a fluid change #70
Typically, a mechanic will want to check what the symptoms are and experience them himself.
Then he will want to go over what you did and see if anything there has contributed to a problem. If he can't find something - and he may not - then the the next step is to get out your shop manual and check the hydraulic pressures.
There are standard test ports that he will spot immediately for the main tractor hydraulics on the main pump and on the FEL control.
Then with the aid of your workshop manual and those pictures you posted he can also find the ones for the HST system. Pressure values should be in the workshop manual.
The pictures also show a schematic - the diagram with hydraulic symbols. That is very good, because with pressures and that schematic then he can probably find the problem.
To do this in the best way, one of you will need a hydraulic gauge test kit and adapters - better ask if he has one to bring it.
If it is you doing the work, Amazon has hydraulic test kits. Look under "hydraulic test gauge kit". They aren't expensive. The challenge is getting the proper threaded adapter to fit your test port. Most of the hydraulics on the loader control valve are universal, but with the HST getting the right adapter is always a gamble.
rScotty
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2018 Gatormade 20+5 Gooseneck Trailer (A55302)
2018 Gatormade...
UNUSED FUTURE CW59 - 59" HYD COMPACTOR WHEEL (A52706)
UNUSED FUTURE CW59...
