Kubota 2000 L2500 Clutch question
   / Kubota 2000 L2500 Clutch question #11
I hope you never drive with your foot on the clutch and if there is a retracting spring on the linkage to pull the bearing away from the pressure plate, be sure it is doing its job.
Monitor your clutch freeplay.
   / Kubota 2000 L2500 Clutch question #12
Throw out bearings are factory pre-lubed. You cannot lube them. Scotty
True most of the time. i recall on my '70 IH Scout (304) there was a zerk for the throw out bearing underneath the chassis.. the only one i've come across
OP: best of luck in the repair, regards
Yup, my 1962 Toselli crawler had a grease fitting for the throw-out bearing.
As you say and show, there's no reason to design the common throw out bearings so that they can't be lubed. That's just the way that most are.
And I bet every mechanic out there has tried some sort of trick to lube an "unlubeable" throw out bearing. I know I have. I'll probably try it again, too......Don't recall it ever working though.
rScotty
We are all glad to help, I'm sure. Speaking for myself as a long time mechanic and repair shop owner I am still trying to figure out just how to make internet help effective. So help me too....
Just so you know, most dealers make quick estimates based on the cost for parts then double that to cover the labor. With that in mind, $2500 for a clutch job is not far off. Depends on what they find.
And keep in mind that some mechanics just naturally replace anything at all worn when they are in a tractor that deep, whereas others only fix what is wrong.
In the past, I don't think that I've spent enough time just asking these initial questions to get a feel for the owner's abilities and the tractor. Some photos along with a history of the tractor would sure help too
So what can you tell me about your mechanical abilities? Tools? Shop...Do you enjoy mechanical projects? You are going to need a flat floor space longer than the tractor, a Harbor Freight crane ($200), and a dolly stout enough to gently roll half the tractor away from the other half. And a clutch plate lineup tool.
Oh, almost forgot.... do you have a workshop manual for specs, and a parts book so you can post pages here on TBY so we can all point to the same part?
Luck,
rScotty
From being a teenager, I have always worked on my vehicles, motor replace, clutch work, etc. I have never worked on a tractor other than front seals, bearings on the 4 wheel drive. I have a shop building with plenty of space, plenty of tools, I don't have a clutch plate line up tool. I have a cherry picker, 2 floor jacks, air tools. 2000 Kubota L2500 with FEL, 850 hours on tractor, I bought it a year ago. I do not have a repair manual or parts catalog. I ordered throwout bearing and clutch from Messicks and got them today. clutch diameter is 8-3/8" which looks small, (I have not taken the tractor apart yet) so I don't know the diameter of the existing clutch. I read another post about securing the front bumper to a wall to keep it from turning, would jack stands under both sides of axel keep it from turning. Do I have to take the loader off?? Thank you
I don't ride the clutch, but I think I need some play in the pedal.
   / Kubota 2000 L2500 Clutch question #15
One thing to keep in mind while splitting the tractor, is that the front axle pivots. A lot of people miss it, then they go to split the tractor and the entire front half just tilts one way or another and makes for a very unpleasant experience.
To avoid this, get some wood wedges and jam them between the front axle and the frame of the tractor, on both sides.
Thank you, good idea. Do I need to take the fel off to split the tractor.
   / Kubota 2000 L2500 Clutch question #17
Yes, since you'll have to remove the loader mounts in order to split the tractor.
   / Kubota 2000 L2500 Clutch question #18
Jack stands under the axle won't help any differently than having the tires on the floor. The axle stays put either way. The problem is that a tractor has a single center axle pivot right in the middle of the front.
So as soon as you remove the last of the bolts that hold the bell housing, the whole front of the tractor& engine will immediately try to lean to one side all the way to the stops as it pivots around that single center axle pivot axle. As it leans, it can trap your fingers between the axle and front frame if you don't have those shims in place to stop the lean.
An alternative way to stop the front from leaning over to the stops lean is to hold the front up with the cherry picker. Anotheris to bolt the front fender to the wall. In either case, the front half stays put and you split the tractor by having a floor jack under the tranny before you split it. Then you can just wheel the rear away from the front.
Yes, you ought ot take the loader off. That's usually the first step.
Good luck.
   / Kubota 2000 L2500 Clutch question #19
Getting parts for 2000, L2500 Kubota with FEL, throw out bearing and clutch replacement. Dealer wanted 2,500 to 3,000. My first time. Will look at some youtube. Any advise on this procedure.
WhenI did one for the first time, I hired a country mechanic to work with me. The biggest help was the "splitting" stand that he had that bolted to the tractor and allowed you to roll away the other half.
The whole thing was no big deal. We only used a few tools and he mostly did the smart things while I did the grunt work. When done he asked for $150 and I gave him a real good tip. I would say it took a few hours.
If I were to do it again I would still get a shade tree helper and be an understudy to them. Something like a retired truck or auto mechanic, that kind of thing. I would not try to do alone or do unless you had a simple splitting stand with wheels on it. That takes all the risk away.
Good luck.
Ok, Thank you.
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
