Mahindra 5155 Anyone?
/ Mahindra 5155 Anyone? #681
Going to the dealer next week. Still undecided between the 4550 and 5155. Will mainly use it for grapple/FEL work after Helene’s devastation. I have other tractors for regular tractor stuff. With the rebate dealer quoted $28,000 for the 4550 with FEL. Any ideas if this is a decent deal and how much more the 5155 would be?
do yourself a favor drive both before deciding and if you are mostly doing FEL work, think about the 5145, no turbo to keep up with and about 5k cheaper for 10hp less. my 5145 was 29k 2 years ago.
/ Mahindra 5155 Anyone? #682
How about aftermarket filters? Fuel, hydraulic, air and oil filters for the 5155.
I looked into that before I did my first service. I found that my local Mahindra dealer had all of them in stock for less than what I could find aftermarket. Maybe that’s changed but I think you might be surprised if you actually price everything out.
/ Mahindra 5155 Anyone? #685
Arrow and Andy, I bought the 5155, mostly on your recommendation, that's what I am telling my wife. It will be delivered in a few days. Supposed to include the owners manuals for the tractor and loader. What plate is used for the quick attach bucket? Regular skid steer? Thanks for your help and I am blaming you guys for the depletion of our checking account!
Aftermarket Wix 51324 oil filter, dealer is 40 miles away and I don't often get up there.
I’ll be the bad guy with your wife if that’s what it takes for you to get a new tractor! I think you’ll like it. Quick attach is the standard Skid Steer type. All your standard stuff will fit. Let us know when you take delivery and what your impressions are.
/ Mahindra 5155 Anyone? #687
I know you’re not familiar with the older Mahindras such as the 4540, but the 5000 series made a literal 100 improvements over the older models. It is a very good tractor.
Good luck with it.
Since your wife doesn't know us from Adam, you could have said Santa made you do it to perhaps better effect.
You could have said Santa has a red sleigh that says "Mahindra" on it.
/ Mahindra 5155 Anyone? #688
After 64 years, we have very few secrets and it is impossible to trick her. She can read me like a book.... a comic book! I made two good decisions in my life, marrying St Sandra and quitting smoking before it was fashionable.
I have a set of forks and I am going to try and fabricate them to a plate, anybody got any pictures of ideas?
Thanks for all your help.
/ Mahindra 5155 Anyone? #689
/ Mahindra 5155 Anyone? #690
Tractor is to be delivered Monday. Maybe that will make it stop snowing. Report will follow Monday evening.
/ Mahindra 5155 Anyone? #691
2023 Mahindra 5155 with right at 80 hours on it so far...
Tractor has been a work horse... I love the thing.
Noticed this yesterday... working on moving downed trees with my grapple. Coming to full stop, clutch all the way in, using the shuttle shifter from forward to reverse, it's having a hard time going back into forward... 2 out of 3 tries, it does not engage.
I've been very careful with this, because I know that the cable is a known problem area.
It goes into reverse with no issue, but forward seems to be a problem.
Any advice?
I don't want it to fail me completely.
/ Mahindra 5155 Anyone? #692
Any advice?
You could probably adjust the turnbuckle at either end. I'd want to look and make sure the entire cable wasn't sliding when shifting to forward, before adjusting.
/ Mahindra 5155 Anyone? #693
Tractor got here this morning, drove it around and everything seems to work. It is bigger than I thought it would be and barely fits in our barn cellar door. I got the back blade off the old tractor and son I put it on the 5155 this afternoon in the cold and wind. Yep, the Roll bar is a brute, but we struggled and got it in the parallel position. Has to be there to get in door for winter. PROBLEM I don't believe the remotes have even been used. Went to hook them up and one female won't accept the male fitting. One works just as it is supposed to but the other one you can't get the male into it far enough for the detent balls to engage. It is definitely that female fitting because both males will work in the other female. Is there a fix short of a new fitting?
/ Mahindra 5155 Anyone? #694
I haven’t run into this with the 5000 series but have confronted what you’re describing with other models. Press in the bad one to relieve pressure and then see if it accepts the male.
If that doesn’t work,
It is one of two things.
1. There is a spec of debris in one of the female fittings.
2. And most likely, there is a brand of remote connectors that are hit or miss. Some fit nicely and others are a bear to put together..
If the Connector is pristine with no visible reason to be defective, just change it out and rid yourself of the headaches.
/ Mahindra 5155 Anyone? #695
There are new males in the tool box and I am going to try one of them in the morning. I really like these safety disconnect fittings and have never had a problem...especially with a new tractor. We were in the 20 degree wind and not dressed for a problem!
/ Mahindra 5155 Anyone? #696
It has been sitting outdoors in freezing weather, so I am going to put the heat gun on it, and get the tools around to take it off. After I get it warm I'll spray some penetrating oil into it. It is in a nasty place, it's the lower remote. I have an extra female fitting but it isn't quick disconnect.
/ Mahindra 5155 Anyone? #697
Also get the tractor running and use the hydraulics to start heating up the oil especially the steering going lock to lock and holding steering there for a few seconds.
After you shut the tractor off and relieve pressure by putting the fell in float, On the difficult female, take a screwdriver and press in the engagement ring inside the fitting. This should drain out the immediate residual oil.
Then try putting everything back together.
If that fails, change out the fitting to one that is less ornery.
/ Mahindra 5155 Anyone? #698
Brute force and awkwardness won again. I got a heat gun and got it good and hot and sprayed it with PB Blaster and my penetrating oil and put one of the new males on a piece of pipe and hit it with a hammer and it snapped right in. No idea what the problem was, just new I guess. It works now!
Now back to playing with my new tractor. Driving position is good and I like how the controls are laid out. Going to have to get used to the clutch. The depressing angle is different from my other two tractors and the clutch is lighter. No place for a mirror to watch equipment behind me. No level bucket indictor.
/ Mahindra 5155 Anyone? #699
My level bucket indicator is in the photo circled in orange. For mirrors I got these and fitted them to the loader uprights. Photo before the mirrors were installed.
Amazon.com
/ Mahindra 5155 Anyone? #700
It's difficult to find a virgin these days.
You obviously found one.
Congratulations to your new tractor.
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
86 (A63290)
86 (A63290)
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
