Snowcat hydrostatic conversion
/ Snowcat hydrostatic conversion #1
trackhead
Member
DIY Snowcat
I have a DIY snowcat I built ground up with 1 ton differential/brake steer configuration that is somewhat spartan that I'd like to convert to hydrostatic drive. I'm a newb in this compartment, so bear with me. Looking for initial build ideas/concepts before possibly venturing down this path this summer.
Currrent engine:
Yamaha RX1 4 stroke/4 cylinder snowmobile motor 140hp/85ft pounds torque
Ideal RPM for this motor is 6-7,000
Internal gear reduction 1.19:1 at shaft
Idea:
-Seems like optimal input RPM for tandem pumps is around 2000-3000rpm.
-Utilize chain drive gear reduction from output shaft of current motor to reduce RPM 2:1 or so to meet RPM input requirement/increase torque.
-Utilize bearing to avoid axial loading of pump.
-I'd like to stick with this motor because it's already mounted, functional, reliable but I realize a 50-60hp diesel might be more suitable, but finances are a concern.
-Seek expert advice on appropriate GPM, motors, etc.
Specs:
Weight 2,000lbs wet
Width 76"
Ground PSI 0.5
Thanks for any input.
/ Snowcat hydrostatic conversion #2
Trackhead,
Is your desire to completely remove the existing differential and brake steering or just make input into the differential a hydrostatic drive.
Either way some of the things that will have be taken into consideration are:
1) machine max loaded weight
2) desired tractive effort - drawbar pull.
3) desired slope capabilities.
4) desired operating speeds
5) track drive sprocket pitch diameter
The above information is then used to start calculating the required track drive torque and input RPM
Then you can decide are you going to use a gearbox with small motor to drive tracks or a larger hydraulic motor to direct drive tracks.
Once hydraulic motor size and RPM is determined you then start figuring the pump size based on flow requirements and input RPM from the engine.
Then typically you start looking at I can get this size motor that operates at this pressure will it work? If yes now what pump option do I have.
General rule of thumb is that a well designed hydrostatic system is at best 85% efficient so that needs to be factored in also.
Hopefully this information provides you with some idea of some of the steps required to obtain a machine that operates close to the way you expect vs it won’t pull its own shadow downhill with a tailwind..
Thx, looking for a starting point of discussion.
1. Remove all drive components, replace with hydrostatic
2. Drive accomplished via hydraulic motor per track
3. Desired speed max 12mph, typically 6-8mph
GVW would be 3k, but typically closer to 2500lbs.
Thx again for the insight.
/ Snowcat hydrostatic conversion #4
I did some digging in my old reference handbooks and found a table showing drawbar pull per 1000 lbs of vehicle weight on level ground. The chart shows 25 - 37 lbs for snow
Formula to figure axle torque is: T = F x R
T = torque in-lbs
F = drawbar pull in lbs
R = wheel or drive sprocket pitch radius
grade resistance formula: F = GR x W
GR = Grade resistance in percent (20% is .20)
W = gross vehicle weight
Using the above info should allow to calculate required torque at the axles.
Travel Speed: RPM = (336 x MPH) / D
RPM = wheel or drive sprocket RPM
D = wheel or drive sprocket diameter
The above can be used to calculate required hydraulic motor speed.
/ Snowcat hydrostatic conversion #5
Currrent engine:
Idea:
Specs:
Weight 2,000lbs wet
Width 76"
Ground PSI 0.5
Neat project.
You'll need 2 wheel motors as well as variable volume pumps, won't you?
/ Snowcat hydrostatic conversion #7
I'd suggest a way to start the motor with the pumps disengaged. Sounds obvious, but the machine I have has a 24hp kohler gas engine with three hydraulic pumps permanently affixed to the engine with shaft couplings. No way to disengage. I don't think my variable volume drive pump puts a tremendous load on the engine when starting since the swash plate is in a neutral position, but it's charge pump is said to take about 3-4 gallons per minute and that's constant. The other two pumps are 4 and 8 GPM respectively to operate steering, front end loader, quick attach from the 4 and PTO from the 8. It puts quite the load on the starter in cold weather.
So just something to keep in the back of your mind.
Sounds like an interesting project. I'll be following. Good luck! :)
/ Snowcat hydrostatic conversion #8
following just because this sounds really interesting as a DIY project. Other than having driven a real snowcat grooming ski trails years ago I don't much useful input.
/ Snowcat hydrostatic conversion #10
it takes alot of energy to drive tracks. I notice the difference on my honda 450 atv . the sprocket is roughly half the diameter of the tire so it is geared down. 5th gear is practically useless unless on hard packed snow going downhill. and top speed is half of the top speed with tires.
/ Snowcat hydrostatic conversion #11
And that's why we have a 1000cc atv. Plus hydrostatic drives waste HP.
Mossroad:agreed on disengagement for start up. Research still in progress.
Arly: I’ve owned a Litefoot hydrostatic cat, a Bombi, tracked UTV, tracked ATV, tracked Samurai. I’m a lunatic and like the building process for some reason. But agreed, don’t want to reinvent the wheel. If I had an extra 80k lying about I’d buy a used PB Scout.
A guy in town built industrial tracked 8x8s for industrial applications and military for 20yrs. He was running 60hp diesel with hydrostatic drive. 3,000lb vehicles. Ultimately I need to sit down with him and figure this out. He’s got decades of building experience and is an engineer.
Still rocking the mechanical drive/CVT but building smaller drive sprockets and might gear the gearbox down a bit further.
Yes, I’ve used/owned every tracked vehicle imaginable. FWIW my current setup is 140hp, it’s geared down from stock 4:1 and has excess power as is due to gear reduction.
Still plows just fine with the arcane brake steer but hydro would be nice. Fun in the yard tonight.
Got the brake steer dialed in might forgo conversion. She’s running great. Thx for prior discussions.
/ Snowcat hydrostatic conversion #16
T = torque in-lbs
I just wanted to take a moment to say thanks for all the things you post on hydraulics. You are a great resource to this forum and I for one greatly appreciate it! (y)
/ Snowcat hydrostatic conversion #17
Thanks for the kind words.
2018 PJ Trailers 14ft T/A End Dump Trailer (A61573)
2018 PJ Trailers...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2016 JLG 800AJ 80ft Articulating Boom Lift (A61572)
2016 JLG 800AJ...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
CHAIN LINK FENCE (A64281)
CHAIN LINK FENCE...
