npalen
Elite Member
The attached shows a Gandy seeder with 12 VDC drive for the seed metering. I wonder how accurate this type of seeding would be given that it would be difficult to maintain a ground speed consistent with the seeding rate dictated by the constant speed electric drive for the seeding rate metering.
Given that many compact utility tractors are hydrostat drive, would it be reasonable to think that a variable speed DC drive controlling the motor on this type of seeder could be matched to ground speed using a potentiometer connected to the pivot of the hydrostat pedal?
I realize that a metering system of this type would have to be calibrated like any other, but the ground speed of a hydrostat in a given gear range would seem to be fairly consistent/repeatable to pedal position assuming that the engine RPM is enough that the ground speed is consistent.
Would enjoy hearing input from you guys as I've often wondered if there could be a more accurate way for homeowners/landscapers to drop seed and fertilizer consistent with ground speed rather than relying on gravity drop for example. It would seem, from a cost versus performance standpoint, that an electric drive synchronized with ground speed could be very competitive in lieu of chains, sprockets etc.
