RESOLVED 🛑 STOP sign on instrument panel
   / RESOLVED 🛑 STOP sign on instrument panel
If I could delete this, I would. I’m not looking for DIFFERENT answers, just answers. So far, only two, ruff dog who was trying his best to be helpful and you, worried about where this is posted. Do you happen to have any input about the issues?
   / RESOLVED 🛑 STOP sign on instrument panel #12
What chance is there that during the repair some wires were pinched? The tractor may have sat for a while so mice damaging wires may happen too.
Definitely not a mouse issue…but there’s a chance of damage to wiring simply from moving them to take off the head. I don’t think that’s the issue, but it’s possible. As I said, I ran it long enough to get antifreeze up through the heat system. I didn’t allow it to idle below 1200 rpm until shutdown. When it was running, I was outside of the cab for a bit, feeling exhaust and looking for any issues. That’s when the stop light illuminated. The engine light was on as I had two codes unrelated (I thought) to this issue.
   / RESOLVED 🛑 STOP sign on instrument panel #14
Have you tried disconnecting the battery for a few minutes to see if the codes will reset? On the 9530 I used to run it through a couple of the stop sign codes. Don’t recall what they were but doing a power cycle reset them. May or may not work for the codes you are receiving.
   / RESOLVED 🛑 STOP sign on instrument panel #15
Yes, worth a try.
   / RESOLVED 🛑 STOP sign on instrument panel #16
And the answer is now in reply #8
   / RESOLVED 🛑 STOP sign on instrument panel #17
It needs to go to the dealership and have the codes cleared.
Resolved…manifold sensors were not plugged in after rebuild. Entirely my own fault. all is well with this tractor now. Thank you all for your input. It’s not always necessary to involve dealer. We can still lean on one another and that is appreciated!
   / RESOLVED 🛑 STOP sign on instrument panel #19
Thanks for bringing this full circle.
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2017 FORD F350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F350 XL...
26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
26ft T/A Dovetail...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
