What can it tow
/ What can it tow #1
Tomtint
Elite Member
Boston
L3700SU
I have a L3700 SU, manual says the 3ph can lift about 2k pounds. I have a camper that's in a tight spot for a pick up to get st.. weighs about 10k pounds.. it's on flat ground.. needs to move about 80 feet.. will the L3700 pull it ? ..I have a skid steer as well and I know that will lift and pull it.. but it's more work to load and move it,
/ What can it tow #6
Lift capacity should be fine at around 1500# (15% of gross weight), it will extend the hook up a few inch back vs on the trailer drawbar... more importantly you will most likely crank that trailer pretty hard to fit it in place (assumption) and that will put lots of lateral pressure on the 3 point links. I just think its a safer bet on the trailer drawbar. Also I don't know how you would fit a trailer ball hitch on a 3 point tractor drawbar as the holes are smaller then the ball bolt unless you simply use a chain ?
/ What can it tow #7
also when backing up with a 3 point there is nothing holding from lifting up... I know you said its flat ground but still not ideal.
/ What can it tow
I have a triangle thing that
also when backing up with a 3 point there is nothing holding from lifting up... I know you said it's flat ground but still not ideal.
i have a triangle thing that goes in my 3ph. Then the 2" shaft with the ball goes in that. ..So that's what I was thinking about using
/ What can it tow #10
Is the drawbar on that tractor high enough and long enough to hook up to a travel trailer? I know my Branson it would be a problem to get the tongue of the trailer that low.
3 point is the only option I would have.
/ What can it tow
Im going to double check that. It may just be easier to bring the skid steer.. At least I know that will not be any problem.
/ What can it tow #12
You shouldn't have any problems, but the tongue weight of the trailer will be approx. 1,100#. That must be considered when contemplating using the 3-pt hitch. You don't want to be doing any wheelies.
/ What can it tow #14
Some check-chains would be a good safety option if using the 3pt. A sudden stop without them could damage the 3pt
/ What can it tow #15
The 3PH is rated at just shy of 1500 lbs at 24” from the lift pins according to Tractordata.com. That would put your 3PH at the roughly 15% of trailer total weight, it should be doable as tongue weight is typically between 10-15% of total trailer weight. If you think it may exceed this level, go to the tractor draw bar.
My concern with lifting close to max 3PH weight would be a very light front axle.
/ What can it tow #16
Why I keep Two tractors. Small Yanmar is mostly just used with a FM. mower. A old ford for the heavy lifting and pulling. It would handle that task with ease!
/ What can it tow #17
If it picks it up, then move it. Especially on flat ground for 80’ ! Needless to say terrain is key here. If the 3ph is stressed out, then you don’t want to be going downhill, while turning the trailer. Let common sense be your guide!
/ What can it tow #18
Down force or Tongue weight is the only thing that will keep the 3Pt. arms down on my Yanmar. You can get into a bad situation easy. Not all tractors are like that. Single axle trailer notorious! I've dumped this one serval times.
/ What can it tow
Thanks all, I ended up just bringing the skidsteer And it was a 5 minute job. It took longer to unload and re load the machine more than anything else.
/ What can it tow #20
Actually the L3700SU according to Tractor Data lift is 1998
