Fender lights 2006 Toolcat 5600
/ Fender lights 2006 Toolcat 5600 #1
Got Juice?
Toolcat 5600
My Fender lights on my 2006 toolcat do not work. I have tested the bulbs and they do work off another 12v source. All fuses in the passenger side fuse panel are intact and working.
All other lights are working. Is there another fuse that is buried somewhere that is missing? Switch still works and the running lights are functional.
I am at a loss, any wisdom would be appreciated.
/ Fender lights 2006 Toolcat 5600 #2
There are 2 fuse panels, one by your rh heel and one up by your rh toe. The one by your toe, fuse 5 and relay 12 is "light". Fuse 6 and relay 14 is optional "drive lights". The heel panel has optional marker lights fuse 3 and 4 and relay 12. This is all on a G series TC.
Not on a 2006... you have pictures of it???
Mine is a C Series Toolcat. Last of the solid axles....
/ Fender lights 2006 Toolcat 5600 #5
/ Fender lights 2006 Toolcat 5600 #6
If the other lights are working (marker lights, overhead work lights), and the selector switch on the dash is working, it has to be a the drive light relay. I believe it will be one of three relays hanging off the harness under the driver's seat. That relay and the selector switch are the only components that will only affect the road lights. A fuse would affect other lights. Could also be a broken wire of course.
Edit: I just looked at my 2006. There are three inline fuses under the driver's seat, one of them is for the road lights. For some reason they are not shown on the schematic.
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
International 37 Square Baler (A65640)
International 37...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
