YM 1600
/ YM 1600 #1
Rocks91
Member
Yanmar YM1600
So I got a ym1600 the other day. The guy i got it from said he ran it out of gas then couldn't get it started again. Looks like he at least attempted to bleed it. My problem is I can't get it to turn over. I assumed he burnt up the starter cranking it. So I took it out and bench tested it. It pops but no spin. Then I took it apart and wires and lotsa rust fell out so the windings are shot. Where do I find a starter for this thing? Are there any other engines that use the same starter? Also I can't seem to find any glow plugs or wires going to glow plugs. Any help or info on this tractor would be awesome. Thankyou for your time.
/ YM 1600 #3
All the Elec. brushes are gone and the wires to them are huge. The Yanmar Motor for the YM1600 is a SM-146 from Fredricks. That is the same starter I use on a YM2000. Models 1600,1700,1900,2000 use it. I had to rebuild it for the same reason you are. They carry most all the replacement parts. Armature, Brush plate Etc...
/ YM 1600 #4
The last time I needed an oddball starter I went to a local starter repair shop. It wasn't as odd as I thought. The shop ordered a replacement and I had it in a week. It was made in Mexico instead of Japan but it fit and worked fine.
/ YM 1600 #5
Thermostart is an electric manifold heater that takes the place of glow plugs. Widely available because they were used on many brands back then, and are on Ebay under $20. I think the only difference between version is whether the wire attaches by a screw or a slide-on terminal - and the screw can be discarded to slide on the later type of connector.
This device has a heater like a car's cigarette lighter and a temperature sensitive valve to dribble warm fuel into the intake manifold. You can test whether the existing Thermostart gets warm when current is applied. Earlier Yanmars had a dashboard button for this, then later models twisted the key left to energize it.
And that starter, IF is is the same as YM2000, YM240 etc is widely available. I see listings on Ebay under $100 but I didn't check Amazon. I bought one of these third-party (China) starters 20 years ago and it still works like new.
Yanmar used a lot of Denso and Hitachi electrical components that also appear on Datsun, Subaru. Mazda etc so the components are available to rebuild existing starters but I think replacing it is a better choice.
/ YM 1600 #6
So I got a ym1600 the other day. The guy i got it from said he ran it out of gas then couldn't get it started again. Looks like he at least attempted to bleed it. My problem is I can't get it to turn over. I assumed he burnt up the starter cranking it. So I took it out and bench tested it. It pops but no spin. Then I took it apart and wires and lotsa rust fell out so the windings are shot. Where do I find a starter for this thing? Are there any other engines that use the same starter? Also I can't seem to find any glow plugs or wires going to glow plugs. Any help or info on this tractor would be awesome. Thankyou for your time.View attachment 2459766View attachment 2459804View attachment 2458613
The YTOG has the manuals for your machine for free. It will help you find a starter and other parts.
As for bleeding the fuel system, Aaron has a great YT video on this.
/ YM 1600
Wow. All you guys really gave me alot of good information. I really appreciate it. I know what to look for now or maybe I'll rebuild it myself. Being this is my first tractor I'll probably have a bunch more questions in the future. I've never used a forum so if I'm not doing it right please tell me. Hate to ruin what seems to be a good resource to have.
/ YM 1600 #8
You're doing it right. Don't be bashful about asking anything.
I and many others started here with exactly the same question: "My first tractor. What do I need to know?". Some of us stuck around to encourage each succeeding generation of new owners.
Plus there are a few folks who owned these when they were first imported, nearly 50 years ago. Their advice is profound.
Welcome aboard!
/ YM 1600
Are you talking about the Facebook group?
/ YM 1600 #10
NOPE. They don't offer free manuals and nor do they have nearly 2,793 members like we do.
Plus try searching for anything on the FB group, it is a major pain.
The YTOG link is below in my signature in big print. :D
/ YM 1600
Welcome aboard!
Yes thankyou so much. I love figuring out and repairing old machines. I figured this would be a good way to learn tractors. Learning how to split a 16hp tractor will be more forgiving then a 60hp tractor i assume lol. So far the only thing slowing me down is that it's an old rarish gray market tractor and certain parts are hard to find.
/ YM 1600
Alright I think I'm signed up lol
/ YM 1600 #13
From your description it sounds like the previous owner cooked the starter windings, which means that you cannot rebuild the starter. It would need to be rewound and this can really only be done by a shop that rewinds starter and other motors. However, if the rest of the tractor is in good shape spending a C note on a starter is a good investment. I have a YM 2310 that was made in 1980 or 1981. The machine is a beast for its size. It has a front end loader and I use that tractor so much and it just keeps going and going. I think you will be very happy with your Yanmar. When you do have a working starter don't spin it more than 20 seconds when trying to start the tractor. Let it cool a bit before trying again. You probably need to bleed the fuel system since the previous owner said he ran it out of fuel. This is easy to do and there is lotsa info on this site about how to bleed the fuel system on your particular tractor. And DO NOT use starting fluid on you tractor, it can cause all sorts of really bad problems. There is info on this site about that too. Some diesel engines can be used with ether, AKA starting fluid, but Yanmar engines of your vintage can be broken badly by using starting fluid.
Eric
/ YM 1600 #14
We all here share that hobby! :)
... only thing slowing me down is that it's an old rarish gray market tractor and certain parts are hard to find.
You'll be surprised - Back then Yanmar built things to be owner-maintained, anywhere in the world, in almost all cases with the simple tools any farmer would already have. The company continues to have a strong pro-ag attitude.
And back then they went to the existing suppliers of the electrical systems on Japanese cars and motorcycles for starters, alternators and regulators, lights, the choice of which battery, and I suppose they used industry-common parts like the clutch assembly. So the parts an owner is likely to need for maintenance are available anywhere, so long as cross-reference info is available. And that's where this forum and Maverick's YTOG are valuable.
These old Yanmars are like old VW's and Jeeps for continued parts support, now by third-party suppliers. The US is only a small part of the world market where these were exported, are still in use, and are well supported.
Some Yanmar folklore you may not yet have discovered: 30-40 years ago refurb factories in VN bought used Yanmars, swapped parts around until there was one complete tractor, applied a museum-quality paint job, and sold them over here. A few were misrepresented as new. Most of these tractors, like yours, then provided excellent service for another generation. Much of this forum was discussion on these.
Yanmar also had dealers in the US that sold US-spec models. Then closed them to build for John Deere for a couple of decades. Then returned to the US more recently - with sophistocated complex modern tractors that don't have much in common with our YM-series ones.
/ YM 1600
Cool information. Thankyou. I've heard they were very reliable.
/ YM 1600
I can't seem to find any sm-146 or even fredricks.
/ YM 1600 #18
/ YM 1600
Ok. New starter came in the mail and it looks to be for a smaller motor. Said "yanmar various" so I gave it a try. Can I please just get a link or something to the right starter? I'm tired of f*cking with it. I bought a nice fuse block so I can redo the wiring and a fuel/water separator because some past owner thought it was cool to bypass it with some gas filter. I'll post a pic before I change it. I need to go find a bolt to match the old separator holes first. Also I flopped the wheels back out so I had a wider footprint and found oil all over the inside of the wheel. Checked the transaxle and found it almost empty. I assume it's just a seal fix but tractors are a new animal to me. Please advise.
/ YM 1600 #20
What starter did you order? This should be the correct part number per parts manual. 124450-77010
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
John Deere 925 Cultamulcher (A66408)
John Deere 925...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
1500 Gal Stainless Steel Tank (A64127)
1500 Gal Stainless...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
