Deere 410 loader cylinder rebuild kit which ones?
   / Deere 410 loader cylinder rebuild kit which ones? #1
KennyG1982
1999 John Deere 4100 w/410 loader
I have a 410 loader S/N 006943 with the AH 163577 hyd cylinders. I can't find the S/N lookup for the loader but understand there are different kits based on that. Could somebody point me to the S/N lookup or tell me is the AH 176343 rebuild kit is correct for my cylinders?
Thanks,
Ken
Pace, FL
   / Deere 410 loader cylinder rebuild kit which ones? #2
When I first got my backhoe and a cylinder started leaking, I went to my local dealer and bought a rebuild kit for it. The kit had all the parts in it for at least a dozen different models and cost over $100. Then they decided that I had to buy a replacement piston for their rebuild kits. That was another $150 just for the piston.
Since there was nothing wrong with my original piston, this became an issue that I wasn't happy about. The guy at the parts desk understood this and told me that their mechanics never rebuild they cylinders on their machines, they send them out to a hydraulic cylinder rebuild shop. He also told me where it was, so I went there with my cylinder, and he rebuilt it for less then the cost of a rebuild kit.
All I had to do is bring the cylinder to him, and wait for him to call me to pick it up. Usually it's only a couple of days. The guy at the rebuild shop orders just the parts that are needed. Usually it's less then $5.
Rebuilding a cylinder is a pain. Its very hard to get it back together without damaging the new seals. Just getting it apart can require special tools depending on the cylinder. On my backhoe, they do not all come apart the say way, so that takes time to figure out. They are heavy, and hard to hold in place, even on a bench with a big vice.
Ask around, do some online searches, and figure out where everyone takes their cylinders to get rebuilt. The time it takes to figure this out will be worth it.
   / Deere 410 loader cylinder rebuild kit which ones? #3
Thanks,
Ken
Pace, FL
Welcome to TBN!
@EddieWalker is correct in saying that cylinders can be difficult to rebuild, but in this case, if you are mechanically inclined, you should be able to do it.
The kit is correct. You don't need the S/N as you have the loader cylinder number. The kit runs about $35 from Deere.
   / Deere 410 loader cylinder rebuild kit which ones? #4
Take it to the local hydraulic shop. They have the experience and the tools as well as the ability to tell you if any other parts are required.
Thanks for all the suggestions and I will rebuild on my own. I am used to doing motorcycle forks, and have a pretty decent mechanical acumen so this is something I know I'm capable of. Also thank you for the welcome and I'm looking foward to getting into a new hobby.
God Bless,
Ken
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52128)
Heavy-Duty...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
