/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY
irvingj,
I believe the front of the battery is what's closes to you when the information on top of the battery is orientated so that you can read it.
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,602
Oops... I guess I forgot to post the images I found -- here's the first one I found, which was corroborated with a second image that was from a different source. Both agree: with the (long) edge with the terminals on it facing away from the viewer, the R or the L (or no letter=L) indicate the position of the positive terminal. (Never saw that before, but note that a "3" type has the terminals on a short side!)
And although it may well be that either battery would (and certainly could) work for my 2310, in my tractor there ain't a lot of leeway so I'll stick with the 51R battery. Supposed to arrive tomorrow.
KC-- yes, that was my thought as well (logical, no?) but note the image of the NAPA battery: when the top-side label is right-side-up to the viewer, the terminals are on the front edge; on my battery, they're on the rear edge, but both batteries are apparently of the "R" variety.
Sorry to cause more confusion to the battery positive post orientation.
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,605
Ha! Don't worry abut it, life is all about learning. I have to admit that in all my years as an auto mechanic (OK, not a lot, but off and on over a period of 25 years or so, still do most of my own work) I never gave much thought to "51" vs. "51R". Guess I never had to deal with that question before because I was able to just follow the number that was on the original battery.
So, as they say, "Now you know!"
And yet another PS: Over the past 3 days, I've had to use the tractor/blower a number of times... and yes, it started just fine without any help other than the block heater.
Gee.. maybe I can get another 5 years out of that battery....
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,606
Plugged block heater in today and about 2 hours later started the GC2410 easily by just using the key.
Plowed some snow in the back over to the neighbors using the tractor for about 1 hour.
Parked it in the garage and hooked up the NOCO genius G750 maintenance charger and it still only lights up the orange light at the bottom which is showing "on standby".
Purchased a new NAPA maintenance 1.5A charger for $25, and plugged it into the tractor, and it shows green light which is working fine.
Battery appears to be healthy but also checked price on a Napa Legend 12V battery, Group 51, 600A, 500cca, for $179 after old battery returned and AAA discount.
I do hope irvingj solves his battery issues quickly so that I do not have any more battery issues for a while, ha.
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,609
1.8 F this morning. driveway drifted in. we run AWD Escape with Falkan tires and 4WD Silverado 1500 truck with aggressive Cooper tires so no worries.
course gc2400 no start.ran glow plugs 3 minutes, gc2400 huffed.
plugged block heater in for 20 minutes gc2400 running.
before could even think about what to do with driveway people at door with vehicles no start due to bad battery connections.
so unplugged tractor got their crap started and called it a morning so far.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,610
Mine has always started right up.
I have no block heater, and never use more than 30 seconds of glow plug time.
Like Irving's battery, I guess it will remain one of life's great mysteries. 🤔
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,611
I prob could have gotten it running off plugs but my battery is 12 yrs old.
last year I replaced glow plugs (due to one dead one. was a gap in it so...yeah...dead) with aftermarket that are 1/8" shorter and 150$ cheaper so I have to run them a touch longer.
when its that cold out it really is just easier on my body to plug it in and walk away, could have started it on plugs but why bother?
hell one single shot of ether would have made it run...nope.
I spent 145$ in 2020 for a block heater.
I built a dongle to power my battery maintainer and block heater.
its that cold out plug it in walk away for 20 minutes and then tractor running fine.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,612
I got 14 years of reliable battery life from the original. It outlasted my battery maintainer even, now I have a Delta battery maintainer for the new Walmart Everstart Max. So far so good.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,613
I'm hoping to get a break from the wind for a day or two here, been needing to clear drifts twice a day, almost every day for the last 2 weeks. It's really getting old. National Weather Service has the winds below 15MPH for the next 2 days with low snow so the drifting should not be as bad. I would be happier if the wind stayed below 10. But rain expected tomorrow, so that's a different job. I'll be out spreading a ton of salt in the rain or I'll have a skating rink.
I always run my block heater when it's cold if I have the time. I've started without it when I can't wait, but it does start faster with less glow plug time after the block heater has been running for a while. I see no reason not to use it since I have it and I can turn in on from inside the house.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,614
Well KC... you were right.
In spite of the TWO different diagrams I found indicating just where the positive terminal is located on "R" batteries, apparently Deka sees it differently. ARRRGH!!!
Holy f-ing $#@. You'd think there'd be SOME kind of standardization here. Had my son see what he could find, and at first he came up with the same two diagrams I had showing polarity positions... then found another that was perfectly opposite. Sheesh.
I've called (Battery Mart, Winchester, VA) to make arrangements to return this one and order a PLAIN 51 battery, but of course had to leave a message. I really don't want to try to finagle those cables to change their positions in my tractor.
On a positive note, this new Deka battery is substantially heavier than the OEM one. Of course, it also comes without a handle....
Good thing my original battery seems to have come back to life a bit -- we're due for more snow tomorrow afternoon. I had to use it again this AM to clear a couple inches that arrived overnight, and it started up just fine with heat from the block heater and a bit of glow plug.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,615
I got enough cable slack to make that work in my gc2400.
if it would help you ship it to me and I'll toss my 12yr old napa in box and return to you.
only if that helps of course :)
You'd think they could of made it simpler by identifying the positive terminal with a "L" and a "R".
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,617
Yeah, it's amazing... Look at these two images of "51R" batteries, where the 51R designation is easily seen on their labels. First is (as above) the Deka, second is the Walmart Everstart.
In both cases, I suppose, you could argue the positive's on the right... but on the front edge of the Deka and on the back edge (like my OEM battery) of the Everstart.
Dave, I was hoping to not have to alter anything, but I guess I will take a very close look at the cables on my 2310 to see if I can swap their positions. (Grrrr..)
Also -- apologies for my rant (and language) above... I was feeling pretty frustrated yesterday.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,618
OK, that Deka battery is all in. I have no idea why it didn't occur to me before to flip the battery around, other than that the two cables on the OEM battery attached to the forward edge, away from the instrument panel and all its wires & cables...and well, that's the way it was originally set up.
But it did work to rotate the Deka battery 180 so the posts were facing toward the REAR of the tractor instead of toward the front, so the positive & negative posts were at least on the correct sides.
That meant the cables only had to move about 2-1/2" toward the rear, so they fit without too much trouble. Those little 10mm bolts on the cable clamps are now very hard to get at (especially the positive), but I managed to get them tight; it'll also be a bit of a reach to connect a charger to the battery (when & if needed), but also doable -- still, it'll be awkward.
In any case, it's now all installed and I have to admit that she cranks at a substantially higher RPM now with that new battery. Bet that'll go a long way toward being able to start better!
(That blue bungee was used to keep the wiring harness up & out of the way.)
Another lesson learned.
Great news irvingj,
Now my money's on your new battery to break another worlds record surpassing
"17 years and 1210 hours", ha.
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,620
sigh...no new battery for me in exchange for a 12 yr old napa battery is what I get from this post :)
oh well glad you got it all working my friend.
fwiw attach this once and be done with it.
NOCO GENIUS2D
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2011 Kubota KX080-3 Midi Excavator (A59228)
2011 Kubota...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
