welding on the tractor
/ welding on the tractor #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hello, I need to weld some hooks on my bucket on my 1705, do I need to unhook the battery before welding?
/ welding on the tractor #2
I would at both ends to be sure. (Don't ask me how I've been reminded of that.)
/ welding on the tractor #3
for sure cannot hurt, good time to service terminals\posts also.
/ welding on the tractor #5
Also place the ground clamp as close as possible to the weld and make darn sure the welding current cannot go through any bearings. I probably didn't need to say so but folks do sometimes make the mistake of having welding current passing through stuff that rotates.
Eric
/ welding on the tractor #6
Eric
GC1705 uses DL100 FEL which is just a greaseable pin. pretty much built in slop :p
/ welding on the tractor #7
Not familiar with your model, but it might be easier to disconnect the bucket instead of disconnecting the battery. Getting to mine is a PITA.
I don't have quick release on my bucket so I will have to do it the other way.
/ welding on the tractor #9
I am so glad I went with the Bobtach quick release system, I’m not even sure if Bobcat offered permanent attachment in 2009.
/ welding on the tractor #10
it takes 5 minutes to fully remove a DL100 FEL (Front End Loader) from GC series tractor. I often do it multiple times a week.
/ welding on the tractor #11
I have welded several times on my tractor without disconnecting the battery. I simply grind a bare spot for the ground clamp close to the work area to ensure the path way.
My work included some heavy bucket hooks.
/ welding on the tractor #12
My 'work' included wrecking an instrument cluster, esp the tach which now pins the needle at low idle.
PTO speed is now 'sounds about right'.
You guys go ahead & I'll wait to hear if you got luckier than I did.
/ welding on the tractor #14
No. I've welded on many tractors/backhoes/skid steers/dump trucks/pick ups, and didn't unhook the battery.
/ welding on the tractor #15
You can take the front bucket off the loader frame in a few minutes too.
/ welding on the tractor #16
on a dl100 yes, very easy. like 15 minutes. remounting little more time consuming.
on dl95 little harder.
dl100 is 7/16 socket and wrench and a ball peen hammer :)
/ welding on the tractor #17
I usually take mine off in the fall to mount the plow, and put it back on in the spring.
I can do it in a few minutes. Pull the screws, lower it on to a dolly, push the pins to one side, with a drift, until they clear the arms, and roll the bucket away.
/ welding on the tractor #18
If you've ever spent any time around a grounded welding table, you'll notice that there is often a spark between the work and the table when an arc is struck, that can happen inside a bearing if the current passes through it, causing a pit, and subsequent early failure. That's why people recommend placing the ground as close as possible, plus you get a better weld with a secure close ground. As for the battery disconnect, with the newer stuff that's loaded with mosfets, you definitely want to open the circuit that could introduce spurious voltages. Even on the older stuff with steam gauges, why risk cooking an alternator diode, plus, as stated, it gives you a chance to clean the terminals.
/ welding on the tractor #19
I smoked the voltage regulator on my JD-1070 a dozen years ago while moving the front weight bar upwards to accommodate a front snow plow. Yes i had the positive terminal off. Since then it's been remove the part involved if possible or bolt the pieces on I am adding. Same 'religion' practiced on my JD diesel lawn mowers. Fool me once, ....
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
YALE ELECTRIC WAREHOUSE PALLET JACK (A64279)
YALE ELECTRIC...
30" X 12' ADS DRAINAGE PIPE (A64281)
30" X 12' ADS...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
