2018 F450 V10 Dump Truck
/ 2018 F450 V10 Dump Truck #1
Tomtint
Elite Member
Boston
L3700SU
So I have the truck in the title. It's been my plow truck and general heavy tow vehicle, mulch vehicle etc. It has about 15K miles on it since new.. It goes out in the worst of the worst of the worst weather.. Its on its 4th.. Yes 4th set of manifolds, 2nd set of heads, 4th set of brakes, rotors, callipers , 2nd set of trans lines, 2nd set of power steering lines, second set of shocks..... You get the idea. .. Anyway ..A recent issue has been the battery not holding a charge.. Or not charging enough. It cranks over slow at first with a brand new battery. Also, when I have the Boss plow on and use the electric controls to lift and angle the blade.. If the radio and heat are on, The radio and heat shut off until i release the plow buttons. Im wondering if this is a bad ground ...maybe the battery ground to chassis ?
/ 2018 F450 V10 Dump Truck #2
Sounds like the plow is energized when you crank the motor and may be energized while it’s sitting. That is draining your battery.
The plow is definitely energized while cranking, But not when the ignition is off.
/ 2018 F450 V10 Dump Truck #4
Have you checked for a battery draw while truck is parked? I’m not sure what you’re trying to resolve, a parked truck battery draw, or the funky electrical gremlins while running (I think thats what would bother me)
/ 2018 F450 V10 Dump Truck #5
I run my plows through the upfitter switches, so nothing goes to plow until I turn on the upfitter plow switch.
I have not checked for a draw, Im sure with the radio there is always a small one. My belief is that the battery is not charging while its running or that its not charging enough due to a bad ground somewhere.
/ 2018 F450 V10 Dump Truck #7
Whats your voltage amps while running?
/ 2018 F450 V10 Dump Truck #9
Batteries good? (I’m just trying to eliminate the easiest things first)
It only has 1 battery and it was replaced today.. It had a slight hesitation/lag when cranking at first .. Like it was about to go click click click.. But did turn over and start.
/ 2018 F450 V10 Dump Truck #11
I would bet that your rust issues have compromised your ground(s). That is where I would start.
/ 2018 F450 V10 Dump Truck #13
Yeah thats a connection issue. You know what’s going on better than I do on your rig.
How do the terminals on the cables look?
With all your salt up there, could be rusted cable on starter/solenoid
/ 2018 F450 V10 Dump Truck #14
Wow! Just wow!
That's an awful lot of problems for a truck that new! Did you buy this new? I have the V10 in my 2007 E350 and it has been flawless. Been driving it for 17 years now and the ONLY thing that's been done to it is changing a faulty brake switch that was causing the cruise control to occasionally disengage.
/ 2018 F450 V10 Dump Truck #15
Wow! Just wow!
I guess his F450 was not made road-salt proof?
/ 2018 F450 V10 Dump Truck #16
Wow! Just wow!
I had constant blown exhaust manifold gaskets on my 2008 Superduties. That problem has plagued Ford for a long time.
I'm going to look at the cables at the top of the battery closer tomorrow.. the other ends.. I'll have to bring it to the mechanic.. I don't really want to get under it.
Wow! Just wow!
Yes I bought it new. ..But up here the state used Mag Chloride on the roads and salt that devours vehicles.
Got the truck fixed today. It was the starter. Not certain if it was the solenoid or the starter itself. The wires were really corroded so I just had the whole thing changed. 209.00 for a Ford oem part and it cranks over great now.
/ 2018 F450 V10 Dump Truck #20
That’s actually really cheap these days for a starter.
That’s not $209, labor included?
17601CFL (A59228)
17601CFL (A59228)
2011 Ford Expedition 4x4 SUV (A61569)
2011 Ford...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2015 SHOE1999 SER (A61569)
2015 SHOE1999 SER...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Pinnacle...
