Turtle Rabbit switch TC 35DA
/ Turtle Rabbit switch TC 35DA #1
caryandrew
New Holland TC35DA
My turtle/rabbit toggle switch and button control on the loader level is not working. Low and High gear lever works fine. Help.
/ Turtle Rabbit switch TC 35DA #2
This is from the TC repair manual.
/ Turtle Rabbit switch TC 35DA #3
The TC is basically the same as my Case. Mine would sometimes not work and what I found was the toggle switch on the fender would sometimes stick, thus not allowing the buttons on the loader handle to function either. I was looking at TC35 the other day for a friend to buy and it had the same issue.
The TC is basically the same as my Case. Mine would sometimes not work and what I found was the toggle switch on the fender would sometimes stick, thus not allowing the buttons on the loader handle to function either. I was looking at TC35 the other day for a friend to buy iand it had the same issue.
Did you replace the hi/low switch?
/ Turtle Rabbit switch TC 35DA #5
I have not. I did blow around the rocker switch with compressed air and it has not given me any trouble since. Doesn't look like it would be to hard though.
/ Turtle Rabbit switch TC 35DA #6
How do those switches work? I just received my new-to-me TC40DA last night. I didn't have much time to play around with them, but I wasn't sure how they worked. I could operate the tractor in both hi and low range, but I couldn't figure out how to get the fender or joystick buttons to do anything. If anyone can point me to a YouTube video, that would be helpful.
/ Turtle Rabbit switch TC 35DA #7
The Operator Manual states that after selecting either low or high range, the Turtle button operates at or below normal speed, the Rabbit button operates at or above normal speed. Basically makes it a four range transmission so you have better pedal response. I operate in Low range and toggle between Turtle and Rabbit. Only time it goes into Hi range is on pavement, which is very rare for my TC40DA. I normally run at 2000 RPMs for everything. Makes for good loader response for dirt work and pulling power for the arena drag.
/ Turtle Rabbit switch TC 35DA #8
I think I understand what it's supposed to do. I'm just not sure how to make it do it. Right now my turtle light is on. Not sure how to make it turn off or make the rabbit light turn on.
/ Turtle Rabbit switch TC 35DA #9
It's a toggle switch. Push it to the outside to switch to rabbit mode, lights should switch to the active side. Pull it towards you to go back to turtle mode. Top pushbutton is rabbit, bottom pushbutton is turtle. Lights on the fender switch will change with the joystick pushbuttons.
/ Turtle Rabbit switch TC 35DA #10
Gotcha. Sounds like I'm probably stuck in turtle mode then.
/ Turtle Rabbit switch TC 35DA #11
There are two wires on the lower left side below the driver’s foot that activate the servo for the two speed (turtle/rabbit).
Make sure those two wires have not been disconnected.
/ Turtle Rabbit switch TC 35DA #12
Here’s the thread I posted when mine quit working however, mine started working again without me doing anything and hasn’t given any issues since it started working again.
(INOP) CUB CADET 1810 LAWNMOWER (A62131)
(INOP) CUB CADET...
Komatsu D39 PX Crawler Dozer (A61166)
Komatsu D39 PX...
UNUSED CFG INDUSTRIAL MX12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
2019 John Deere X380 Lawn Mower (A63116)
2019 John Deere...
Clubcar Carry All 1700 (A64047)
Clubcar Carry All...
UNUSED WOLVERINE R-31-G1.5T 1R RIPPER (A62131)
UNUSED WOLVERINE...
