IHMT transmission in real world
/ IHMT transmission in real world #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
When I brush hog I want my mower running at 540 rpm. all the time. If I hit a heavy spot, I want to slow the ground speed down but leave the PTO at 540. I have to clutch and shift to a lower gear. Is it the same with the IHMT?
If I understand correctly, you can remove the IHMT without splitting the tractor. How about the engine repair or clutch, or is the clutch electric and part of the IHMT? How about the reverser? My present gear tractor, to do transmission/clutch/reverser repair you have to remove the FEL frame and all the tin to split it. $2000 before you get to the problem, and it never goes back together right! been there, had it done What a selling point if you can do that repair without removing the FEL frame and the tin.
/ IHMT transmission in real world #2
With an HST or the IHMT the pedal position sets the ground speed independent of the engine speed, with the cavat that the linked pedal and throttle will raise the throttle if needed, and the IHMT's A/B switch settings which can limit rpm and travel speed.
So instead of clutching and shifting gears when you get to a heavy spot, you just slow down by letting the pedal up. I have manual tractor and an HST one, the HST one is way better for mowing just for that reason. IHMT would be similar.
From the parts diagrams it looks like the reverser is in the transmission case. There's a drive shaft between the engine and the transmission, which is between the rear wheels instead of bolted to the engine as is more typical.
I don't think there is a real clutch at all. There's not one in the parts diagrams. I think the "clutch" pedal just puts the IHMT in neutral. If so its kinda useless- you can drive it without ever touching it. My HST Branson has no clutch pedal and has the brakes on the left which is more useful than having them on the right where the transmission pedal is.
I don't have a Yanmar though I have been researching them. Maybe an owner can chime in.
/ IHMT transmission in real world #3
The YT3's are fine tractors. The clutch is not the same as an ordinary clutch and is controlled by solenoids on the side of the transmission. So to answer your question, you can maintain 540 in much the same manner as you would with your gear driven tractor. That said, engines only provide so much power and if the engine load becomes too heavy, the rpm's will slow just as any other piece of equipment. You will not need to slow to a different range when mowing as long as you start in the right range. 1st range is for ground engaging and heavy work. 2nd range is for normal work and most work will be performed in this range. 3rd range is for light work and travel. An example of light work is using a finish mower on property that regularly gets cut, therefore the engine load would be minimal.
Advantages of the YT3 are that you can go from forward to reverse without the use of the clutch, much like that of a forklift. You can also adjust the aggressiveness of direction changes and takeoff with the motion control dial. When mowing with a finish mower the operator may want to set the dial to turtle to prevent wheel spin on their lawn. When doing loader work the operator would set the dial to rabbit to get in and out of the pile quickly.
Another advantage is the power to the ground. The YT3 has nearly identical power to the wheels as the YM3 when equipped with the same engine. Add to that, it has the ease of operation of a hydrostatic tractor, minus the power loss.
The cruise control is nice as well. It is electronically controlled and not a throttle lock like most of the other tractors in this category. It can be set at a particular speed, I will use 3 mph as an example. Once set, if you start to go down hill, the tractor will use the transmission to keep you at 3 mph as long as the transmission can keep that speed. When going uphill the transmission and engine will work to keep that 3 mph so long as the engine and transmission can provide that power. The set/- and res/+ buttons will increase or decrease the set speed by 1/10 mph. Very similar to how the cruise control works on a car.
The auto throttle can be used to increase the speed to the maximum set engine speed without increasing ground speed. This can be used to increase hydraulic flow when loading hay on a truck for faster lifting or to increase PTO rpm for a small thick area.
A/B mode can be used to set independent ground and engine speeds. This will do the trick when mowing. You can also set the PTO speed to set the engine speed for precise control.
Probably more of an answer than you wanted, but the tractor is phenomenal and it is hard not to brag.
So, you can set the pto speed to 540 but if you hit a heavy spot and the tractor bogs down and the pto speed drops below 540, you must shift to a lower gear to keep the pto speed at 540, but you don't need to use the clutch? The IHMT doesn't automatically reduce the ground speed to keep the pto at 540?
/ IHMT transmission in real world #5
It does have the anti-stall feature that will slow the ground speed to keep power to the engine. I have cut very tall vegetation with it and not had any issues with overloading the PTO. You don't have to shift to a lower gear / range. It has 3 ranges and much like a hydrostatic, no true gear, just a range. If you use a working range you shouldn't have any issues.
/ IHMT transmission in real world #6
I love the design of the IHMT. Great hybrid of shuttle and hydro. Plus you can service it without spltting the tractor!
/ IHMT transmission in real world #7
You don't shift a gear you just let up on the pedal some to slow the ground speed.
/ IHMT transmission in real world #8
It may be easier to find how it works and get a better understanding how it operates by searching by " Fendt Vario Transmission". The iHMT is essentially a scaled down version of it.
/ IHMT transmission in real world #9
The Fendt Vario transmission is a CVT. The I-HMT is not a CVT. Regardless of the wording used in the advertisement, Vario, it is not the same. The CVT has belts, the I-HMT has a hydraulic pump and motor that lock together. Some of the features are similar, but the transmissions are different.
/ IHMT transmission in real world #10
Go check how Vario transmission works then.
Where do you think Yanmar got the idea for the iHMT from?
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
208316 (A58375)
208316 (A58375)
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
