IHMT transmission in real world
   / IHMT transmission in real world #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
When I brush hog I want my mower running at 540 rpm. all the time. If I hit a heavy spot, I want to slow the ground speed down but leave the PTO at 540. I have to clutch and shift to a lower gear. Is it the same with the IHMT?
If I understand correctly, you can remove the IHMT without splitting the tractor. How about the engine repair or clutch, or is the clutch electric and part of the IHMT? How about the reverser? My present gear tractor, to do transmission/clutch/reverser repair you have to remove the FEL frame and all the tin to split it. $2000 before you get to the problem, and it never goes back together right! been there, had it done What a selling point if you can do that repair without removing the FEL frame and the tin.
   / IHMT transmission in real world #2
With an HST or the IHMT the pedal position sets the ground speed independent of the engine speed, with the cavat that the linked pedal and throttle will raise the throttle if needed, and the IHMT's A/B switch settings which can limit rpm and travel speed.
So instead of clutching and shifting gears when you get to a heavy spot, you just slow down by letting the pedal up. I have manual tractor and an HST one, the HST one is way better for mowing just for that reason. IHMT would be similar.
From the parts diagrams it looks like the reverser is in the transmission case. There's a drive shaft between the engine and the transmission, which is between the rear wheels instead of bolted to the engine as is more typical.
I don't think there is a real clutch at all. There's not one in the parts diagrams. I think the "clutch" pedal just puts the IHMT in neutral. If so its kinda useless- you can drive it without ever touching it. My HST Branson has no clutch pedal and has the brakes on the left which is more useful than having them on the right where the transmission pedal is.
I don't have a Yanmar though I have been researching them. Maybe an owner can chime in.
   / IHMT transmission in real world #3
The YT3's are fine tractors. The clutch is not the same as an ordinary clutch and is controlled by solenoids on the side of the transmission. So to answer your question, you can maintain 540 in much the same manner as you would with your gear driven tractor. That said, engines only provide so much power and if the engine load becomes too heavy, the rpm's will slow just as any other piece of equipment. You will not need to slow to a different range when mowing as long as you start in the right range. 1st range is for ground engaging and heavy work. 2nd range is for normal work and most work will be performed in this range. 3rd range is for light work and travel. An example of light work is using a finish mower on property that regularly gets cut, therefore the engine load would be minimal.
Advantages of the YT3 are that you can go from forward to reverse without the use of the clutch, much like that of a forklift. You can also adjust the aggressiveness of direction changes and takeoff with the motion control dial. When mowing with a finish mower the operator may want to set the dial to turtle to prevent wheel spin on their lawn. When doing loader work the operator would set the dial to rabbit to get in and out of the pile quickly.
Another advantage is the power to the ground. The YT3 has nearly identical power to the wheels as the YM3 when equipped with the same engine. Add to that, it has the ease of operation of a hydrostatic tractor, minus the power loss.
The cruise control is nice as well. It is electronically controlled and not a throttle lock like most of the other tractors in this category. It can be set at a particular speed, I will use 3 mph as an example. Once set, if you start to go down hill, the tractor will use the transmission to keep you at 3 mph as long as the transmission can keep that speed. When going uphill the transmission and engine will work to keep that 3 mph so long as the engine and transmission can provide that power. The set/- and res/+ buttons will increase or decrease the set speed by 1/10 mph. Very similar to how the cruise control works on a car.
The auto throttle can be used to increase the speed to the maximum set engine speed without increasing ground speed. This can be used to increase hydraulic flow when loading hay on a truck for faster lifting or to increase PTO rpm for a small thick area.
A/B mode can be used to set independent ground and engine speeds. This will do the trick when mowing. You can also set the PTO speed to set the engine speed for precise control.
Probably more of an answer than you wanted, but the tractor is phenomenal and it is hard not to brag.
So, you can set the pto speed to 540 but if you hit a heavy spot and the tractor bogs down and the pto speed drops below 540, you must shift to a lower gear to keep the pto speed at 540, but you don't need to use the clutch? The IHMT doesn't automatically reduce the ground speed to keep the pto at 540?
   / IHMT transmission in real world #5
It does have the anti-stall feature that will slow the ground speed to keep power to the engine. I have cut very tall vegetation with it and not had any issues with overloading the PTO. You don't have to shift to a lower gear / range. It has 3 ranges and much like a hydrostatic, no true gear, just a range. If you use a working range you shouldn't have any issues.
   / IHMT transmission in real world #6
I love the design of the IHMT. Great hybrid of shuttle and hydro. Plus you can service it without spltting the tractor!
   / IHMT transmission in real world #7
You don't shift a gear you just let up on the pedal some to slow the ground speed.
   / IHMT transmission in real world #8
It may be easier to find how it works and get a better understanding how it operates by searching by " Fendt Vario Transmission". The iHMT is essentially a scaled down version of it.
   / IHMT transmission in real world #9
The Fendt Vario transmission is a CVT. The I-HMT is not a CVT. Regardless of the wording used in the advertisement, Vario, it is not the same. The CVT has belts, the I-HMT has a hydraulic pump and motor that lock together. Some of the features are similar, but the transmissions are different.
   / IHMT transmission in real world #10
Go check how Vario transmission works then.
Where do you think Yanmar got the idea for the iHMT from?
   / IHMT transmission in real world #11
They're both Continually Variable Transmissions, in the generic sense of changing ratios without steps across a range. In the automotive world and some others, "CVT" has become associated with one particular type of CVT that uses belts or chains and variable size pulleys. But that's not the only type of generic CVT. A HST is a CVT too for example, and so is IHMT.
This is a pretty understandable explanation of the Fendt CVT:
It combines gear and HST like IHMT... no belts or chains like an automotive-specific type CVT.
   / IHMT transmission in real world #12
I'm not sure where the idea came from, but it works much differently. That has a separate pump and motor which is not on the same shaft, the I-HMT shares a shaft. The pump and motor are what makes the transmission, and they are completely different. The website says it is a CVT: Vario Drive
The I-HMT locks the pump and motor together much like a torque converter when it is in the working range. The Fendt transmission has a separate pump and motor as illustrated in your post, therefore they do not lock together. They are both step-less, that is similar. They operate much differently and the I-HMT is not a "scaled down version".
   / IHMT transmission in real world #13
We have been in this road before and you still haven't taken the time to read or watch a video (like the one above) to learn how the Vario works or to learn that CVT is not only called to a transmission that uses a belt or a chain to vary the speeds, just like Eric explained.
About the only difference, is the Fendt puts the motor and pump on different locations, while Yanmar puts them inline but those still works exactly the same way. They really have to, that's how this transmission works.
Yes, the Vario also locks the pump and motor together. You would know that if you watched the video. That's the entire principle of operation of these types of transmissions.
Thank you all and I am looking forward to driving one. However, I got a quote for $51K and that is just too much for a compact tractor regardless of the convince.
   / IHMT transmission in real world #15
It's indeed a great transmission to have but it doesn't come with an hefty price.
   / IHMT transmission in real world #16
PTSG, we have been down this road. I work with the I-HMT on a day to day basis and know it is different. They do have some similarities, but so does every other transmission. I watched the video several times, it is different. I have admitted in the past that I don't know a great deal about the Fendt transmission, but I do know enough to know the I-HMT isn't a "scaled down version". The pump and motor on the same shaft is key to how the I-HMT works, the Fendt doesn't have that. Much different.
   / IHMT transmission in real world #17
Just because the pump and motor are on a different layout, doesn't mean the rest is different. It's still the same principle of operation of the Vario, still functions the same.
Kanzaki, the maker of the iHMT puts the pump and motor inline, while the Vario spreads the pump and motor but connects them with gears. There is still a planetary gear set in the system, since that's the key for this transmission to work the way it does.
Too bad there is very little info about the iHMT out there other than some pictures showing the pump and motor inline, not the rest of the system. That would have helped clear a lot of the things up.
   / IHMT transmission in real world #18
   / IHMT transmission in real world #19
That is the transmission. The pump and motor are both on the same shaft, that is what allows it to hydraulically lock together, that is what provides less power loss than a traditional hydrostatic transmission. That is the entire I-HMT that is on the display stand.
Kanzaki is a Yanmar company. Tuff Torq and Transaxle Manufacturers of America are as well.
The pump is turned by the input shaft. There is a single swash plate that is controlled by a solenoid for position. Forward and reverse are controlled by 3 solenoids on the right side of the tractor. There is an outer shaft over the input shaft that the motor turns which are attached to the gears to make the wheels turn.
Basically, the pump and motor on the same shaft is the basis for the operation and why it differs from other transmissions on the market.
   / IHMT transmission in real world #20
So does the Vario and all the other CVTs that combine the HST with a mechanical transmission. They all lock the pump and motor together... That's the entire concept of this type of transmission. I really don't understand why you keep saying they're different.
You're missing the planetary gear set though. It has to have one as this is the key for this type of transmission to work at the efficiency levels they rate it to.
MASSAGE CHAIR (A58214)
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
