Just another junk chainsaw
/ Just another junk chainsaw #1,921
Had to look that one up. Never heard of it around here and I had a dealer for them local.
Manual info so I could read. Some great info on it.
I fat fingered that, it's a 3601F and it's red. Basically same saw as Dolmar 352.
Dont know that one either.
7901, 166 x3 and 5100/5105 in past about all I done in those.
Have ran 3400 and wasnt no better then my 2000 except it had antivibe. Also some 420 here but to heavy IMO for small saws.
@Hay Dude one of the trusted porters in my chainsaw repair group. Bought 3 new 400 and ported them. If need more info just let me know.
= Brand new MS400 ported, muffler modded and ready to go, $1450 shipped pho, any questions feel free to pm me, ships from Pennsylvania
Farmertec combi. Stihl clone one.
If you use them with funnel’s as much as I do all the time.
No playing Houdini balance act with funnels one handed like those early green spout husky and clone ones.
So close to my oem later husky one.
Was hoping caps were interchangeable but they are not.
Plastic is thick like oem too.
The tool boxes not made like the husky oem one to hold the tools tight or covered to hold in chains. But for price of just one of the husky oem spouts now days. It's nice.
Guy trying to say all poulan plastic clamshell saws only pull 80-100 psi. He says these were all good runners too.
I was like no wayyyyyyy using that Canuck accent.
I showed him common 150psi even on 36cc non strato and 165psi on 40cc strato.
I could have done others too but really wasn’t worth wasting any more time on it.
Just like that. :oops: :cool:
Less then a min once sale ad put on my CRG FB in my group. 346 NE sold PHO. Just no reason to keep it around with 501 and 359 around.
With extra orange cover and new oem recoil decal.
Trying to heat bar oil up to drain out with hair dryer on low.
Worked pretty dang good.
Didnt want to use heat gun on it.
Just getting it all ready slowly after being sick now for 3 weeks. 🤦‍♂️
I busted open a gal of my ER mix today to test and see for myself.
I will say. The 1% bad feedback on turfuel has to be ones that bought cans that was filled with water and coloring etc and returned to box stores or just your typical clueless owners I even see here.
Idle was same, max rpm the same, in the cuts the same. No difference starting and restarting.
I run Efree 89 with VPracing oil 40:1.
The Truefuel is 40:1 from 2022.
Trufuel is 74% alkylate and 40:1 for my choice. I paid like 6 a gallon at Lowes when selling it off.
I seen no difference in starting, idling, max rpm or in the cuts.
Well valuable lesson about going cheap on bar. Archer K095 3/8 84DL.
Archer made in China for a Australia company.
Back against rim and slot close to back.
I removed some heel to shorten bar up. But then I needed to lengthen slot. But in end it now fits.
Just wanted to test ported 359 out rip cutting with 24” buried.
or I would have had to make a 85DL chain. I choose to grind heel to shorten it some then make slot loner to go back for that.
Bit and file made easy work of it like shown.
But being run 20" mostly and then 16". 24" more of a wanted to see thing on ported 359. Ripping no stopping it.
My FB chainsaw repair group. No time to think there just pulled the trigger on another echo 501 🤦‍♂️
Being shipped from TX. Poor saw going to freeze up here. :ROFLMAO:
Never heard of those others. Pass :ROFLMAO: ✌️
/ Just another junk chainsaw #1,937
The little
Poulan​
, Wild Thing, 18 inch, made hell of a lot a wood for the stove today. :)
I had one for a few years... It was a good saw to throw in the truck and not worry about being stolen. It always started, even after sitting in the shed for 3 years when I'd completely forgotten that I owned it.
The only drawback was the lack of vibration dampening.
/ Just another junk chainsaw #1,938
Its all about the chain and how sharp you can get it. :)
Guess next thing to do if it all checks out. Is get one woods ported the way I want it to pull 325 8T or even 3/8 7T.
Prob stick with 325 8 since loving this new C33 and 23RS
Ran a ported one with 325 7 and that didnt tell me squat. But wasnt my saw and I couldnt change it per owner Well no chit it dont bog ported with 325 7. 🤦‍♂️ 😂
Talked to a local guy I know that ports and has got into the racing of chainsaws now. I have ran his ported echo in past with 3/8 on it and looked at his work and one of my trusted porters in my FB CRG.
Thats why I always like the Poulan 260 220 42cc cheap plastic saws in that version. It has coil spring antivibe.
220 same saw and 42cc not smaller like they say on them ;)
Tube Line Trailer 5000 AX2 In-Line Hay Wrapper (A64911)
Tube Line Trailer...
6' Fork Extension (A64912)
6' Fork Extension...
PALLET OF FLANGE CUT-OFF VALVES (A68842)
PALLET OF FLANGE...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2015 John Deere 323E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
