80" of snow this week.
   / 80" of snow this week.
OK, there's about 10 versions of that, which number specifically?
I have never seen more than one for a tractor.
There is only one Hakk. that I know of. Many Nokians. I am 11k in on my tires.
   / 80" of snow this week. #48
I expect most have heard of the snow storm in Upstate NY. I am in the place you read about. My house got 80" in a few days. It was pretty intense. I run a Kubota M6-111 hooked to a Cyclone 92" inverted blower. I hear everyone saying the inverted is no good in deep snow. Maybe it is not the inverted so much as the tractor it is hooked to. The inverted held it's own all the way through. We had a 10 hour span that produced 24 inches. Tractor and blower had no issues. I am running Nokian tires all the way around. R1 are far too slippery on the road as my route is over 25 miles doing 65 driveways. I have been opening up driveways the last couple of days where the plow trucks could not get through. I did one that had a drift that was over the front of my tractor. I just backed into it like pac man. Drift was gone quickly. The inverted blower can back up to stuck cars and pull away from them without leaving a hard pile there.Folks do not want to pay and then have to shovel that. It can back up to the garage door. If you have an inverted blower and having issues check your tires. A back up blower will probably work with any tires but the inverted will require more traction. That does not make it a bad blower just different. It can eat the snow.
We get about 200-240" of snow each season. I run chains all the way around (square alloy on back, 3/8" studs on the front) and a frontier 72" blower off the back pto. The R4's on my tractor are useless after the first snow without chains. My LS has two remotes on the back, and I use one to control a hydraulic top link and the other to operate the chute rotation/direction. The adjustable top link is very helpful in setting the blower to allow the building of a snow mat, and later in the season to tip the unit down to dig into mat. BTW, so far this season we have 140".
We got a 22" overnight dump a couple of seasons back and there's no way an inverted machine would have worked for me. My tractor would have gotten stuck. As it was, I had to put the machine in the lowest gear because the 24" height of my blower was getting a mouth full of that 22" snow. My road is a 1/2 mile long, and it took quite awhile to blow it in both directions. But with a thermos of coffee in a heated cab with some music playing, it was more quite tolerable.
Having the right equipment for the job is 80% of the solution. Knowing how to use it is the rest!
You are right. I am set for deep but seldom use it. Everyone is all up in arms on youtube that a different blower would have worked better. You know what you and I do? We use what we own. Neither going out to spend money for one storm. I bet you have a sweet setup there.
   / 80" of snow this week. #50
I live in Pompey, NY, in the hills southeast of Syracuse. We don't usually get Tug Hill snow amounts, but we have our moments. Coastal storms, like the Blizzard of '93 (The "Storm of the Century") tend to hit us harder than they do Tug Hill.
The JD 4600 and the 1165 snowblower we have now will move a lot of snow. I wish we'd had it back in '93. Officially, Syracuse got about 4 feet at the airport, but we're guessing we had about a foot or so more than that. It was difficult to measure, as it was blowing around a lot. At the time, all we had to move snow, other than shovels, was a homemade plow on the front of my grandfather's Case SC tractor. With a 10-foot drift across the driveway, it took us half a day just to open a 100-foot path to get the tractor from the barn where we keep it to the road, where we could cross and attack the house driveway.
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
1611 (A57192)
1611 (A57192)
MULCHER (A58214)
MULCHER (A58214)
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
